rough idle?
Old Oct 24, 2010 | 07:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
rough idle?
After i start my car is idles horribly, this only started recently, i got the car running thursday and it ran rough for alittle but eventually smoothed out so i thought i just had alot of extra gas in my engine from cranking on it alot. well yesterday i went to take the car around the block and i got half way down my driveway and the car just died....well fast forward, my hot wire to my started was lose so i tighten the bolt down and started the car and its running rough, the batterys charged, the maf sensor new, the injectors are new, so what could be causing me problem now? same thing as in the beginning, too much gas? im kinda lost here that its just starting to do this recently.
Old Oct 24, 2010 | 07:14 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: rough idle?
I'm just going to through out a few things and maybe someone else can help
Fuel Filter
IAC
Cold Start Plug
Old Oct 24, 2010 | 07:15 PM
Engine: L31 350
Re: rough idle?
fuel filter is 2 months old and iv only put new gas through it, my fuel pump is new, my iac is clean and working, and my cold start is new aswell
Old Oct 24, 2010 | 07:16 PM
Engine: L31 350
Re: rough idle?
also might add my timing is set as factory, my plug and plug wires are newish, my ignition module is new, along with my cap and button
Old Oct 24, 2010 | 07:28 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: rough idle?
Spark Plugs gapped correctly?
maybe should check the codes too. Just throwing ideas out there for ya.
https://www.thirdgen.org/service-eng...ht-error-codes
Old Oct 24, 2010 | 07:29 PM
Engine: L31 350
Re: rough idle?
yup, .45, checked that aswell, should i just let it idle tomorrow to see if it smooths out?
Old Oct 24, 2010 | 07:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: rough idle?
Does that mean you have a code 45? If it does, the first thing to do would be to pull a plug and hook it to the coil to make sure you have a good white spark. It may take some time for the plugs to clear off from the gas. Better yet, pull all the plugs and make sure they aren't black.
The next thing to do would be to pull the O2 sensor out of the exhaust and get a good look at it. It may need to be replaced.
Old Oct 24, 2010 | 07:43 PM
Engine: L31 350
Re: rough idle?
no i mean my plugs are gapped at .45 not a code 45, i the 02 sensor infront of the cat? and i'll pull the plugs to double check the gap and the spark, also ill make sure they arent black.
Old Oct 24, 2010 | 07:46 PM
Engine: L31 350
Re: rough idle?
would being low on gas cause this? the reason i ask is because i only put $17 in the tank an my gas gauge went from empty to over half a tank so could this also be a cause?
Old Oct 24, 2010 | 07:52 PM
Engine: L31 350
Re: rough idle?
wait, autozone is showing i have three o2 sensors?
Old Oct 24, 2010 | 07:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: rough idle?
AZ probably means you have 3 choices for an O2S... There's only one, about a foot in front of the catalyst. And it may take some force to remove. Definitely check for codes first before you pull anything off as it may tell you what needs to be pulled. Let the engine get hot (radiator fan turn on and then off again) and make sure the SES light isn't on full time.
Old Oct 24, 2010 | 08:08 PM
Engine: L31 350
Re: rough idle?
my ses? thought that was airbag? also my engine light is on full time but i cant figure out the codes, i think its 1 long flash is 10 and the short ones are 1 but i cant figure it out, it just flashes alot, nd i was looking at AZs job diagram, it said i have two on the back of the block and one on the exhaust.
Old Oct 24, 2010 | 08:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: rough idle?
SES is Service Engine Soon... Air bag is INFL REST light... If your SES is on all the time, the ECM has detected a problem. First code to pop out with the engine OFF should be 1 flash, pause, 2 flashes, and a longer pause before repeating twice and then any other codes. And your 86 doesn't have an INFL REST light due to no air bag.
Trust me, these are not newer cars that have 2 or more O2 sensors, the thing is ONLY in the exhaust pipe under the car. Newer cars (4th gens) MAY have them in the exhaust manifolds, but ours don't. Pull the codes first, though.
Old Oct 24, 2010 | 08:22 PM
Engine: L31 350
Re: rough idle?
ok so it will give me three code 12s THEN the other codes? and ok i believe you.
Old Oct 24, 2010 | 10:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: rough idle?
If everything is working properly, yes, the ECM will spit out 3 code 12s and then any other codes each 3 times before cycling back around to code 12, which means that all errors have been reported. Best to write down the codes as they are being flashed.
Old Oct 25, 2010 | 06:36 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Re: rough idle?
Follow this tutorial I posted earlier
Old Oct 25, 2010 | 09:10 PM
Engine: L31 350
Re: rough idle?
well this morning i checked my plugs, they are alittle black and the gap was off so i will set those next week also i checked my codes and it just kept spitting out code 12, after it went off 10 times i gave up.......i had to stop on the car because i got a phone call that stated my grandpa was on his way to the ER, upon arrival he passed away so i wont be working on the car much....
Old Nov 1, 2010 | 06:33 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: rough idle?
Sorry for your loss. God bless grandpa.
Old Nov 1, 2010 | 07:28 PM
Engine: L31 350
Re: rough idle?
Thank you, i know hes in a better place, that man taught me alot about cars, even showed me how to do a burnout and let me drive for the first time in his new impala the second day he bought it which my grandma is paying off then giving to me., also might add that if it wasnt for him i wouldnt have owned either of my camaros and they wouldnt be running since he funded my car.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
