Check engine light?
Old Oct 27, 2010 | 10:47 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Check engine light?
When i just have my ignition on my check engine light it on but when i start the car it goes off, is this an issue? i ran my codes and all i got was code 12, i got it 10 times then stoped so can anyone say if this is normal or not or is it fine?
Old Oct 27, 2010 | 11:56 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Check engine light?
That's exactly what should happen. The 12 code just says the ecu (computer) is communicating. You get 12 three times then any codes then 12 three times again.
Old Oct 27, 2010 | 11:58 AM
Engine: L31 350
so its normal for it to be on when the cars off?
Old Oct 27, 2010 | 12:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
When the engine is off and key removed? No.
Old Oct 27, 2010 | 12:05 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
If you mean when you turn on the ignition but not actually start the car then yes the light will be on and only go off when you start the engine.
Old Oct 27, 2010 | 12:12 PM
Engine: L31 350
ah ok, thank you i was worried for a minute because it seemed strange that it was on when the ignition was on but when the car is running its off so thank you
Old Oct 27, 2010 | 12:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's actually part of "bulb check". The car is supposed to turn on all the bulbs so you can tell if one is burnt out. It's also a way for an emissions inspector to see if someone took the bulb out of the check engine light!
One funny one is, on a non-gauge ("idiot light") cluster, if you turn the key to "on" without starting the engine, and the alternator bulb is not lit, that means the voltage regulator is fried. That's true for my '86 Firebird, not sure if it's true for all non-gauge clusters- in my opinion it's not a good design. The light should come on if something's wrong, not go out.
Old Oct 27, 2010 | 12:48 PM
Engine: L31 350
yeah i can see it coming on for a few seconds then shutting off like the newer cars but yeah
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
