Garrett leaf blower? (electric supercharger)
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
http://cgi.ebay.com/ebaymotors/ELECT...Q5fCarQ5fParts
Saw this on ebay while looking for performance possibilities for my fiero the description make's it sound legit but I think it's just a fancy leaf blower. Would 3 psi boost even give decent power? I'm just curious thought Id post it here.
Re: Garrett leaf blower? (electric supercharger)
. The blades spin at 6600 rpm for 12 volt and 13200rpm for 24 volt.
u would have much better luck taking basically what they did with that turbo and converting one into a belt driven supercharger,
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Y'know, someone actually put together one of those that actually work. It was ridiculously expensive and heavy, but it put out enough for a 60hp boost for about 10 seconds. They stuck 3 starters to a 6-71 sized blower and connected them to 2 packs of 5 motorcycle batteries. Seems like a massive waste to prove a point if you ask me.
Car: '88 Camaro (Gone...)
And look at the size of the power wires... They are tiny!
If it's honestly drawing enough amps to make any sort of measureable boost, those wires would melt. I call BS on this
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Don't you think if this stupid idea worked that everyone would be running them? I am no SC expert, but 3 lbs of boost? No it ain't gonna help...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my thoughs exactly. probably doesnt spin much faster than a cooling fan. Anything more and you would be looking at much larger loads and larger wires sizes, probably the size of a battery cable.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
that would be amusing to have under your hood at car shows...you could bs all day long about it
i wish someone would give me one to put on the other side of my motor, instant dual turbos ha ha ha
codeysabatini
Nov 10, 2015 04:07 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
buckeyecelt
Sep 24, 2015 05:50 AM
