Crazy idea...but...2 v6s, 1 v12.....
Old Oct 30, 2010 | 06:06 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Been thinking....Idk much about metal fabrication but if the parts can be joined right, I could see it maybe being possible to take 2 v6s and make a v12...forge or weld(something) two blocks together, retaining each's cooling channels and simply using two radiators, join two oil pans or fabricate a custom one, weld together 2 cranks, 2 cams...that or more likely a custom cam and crank would have to be made.
I wonder if it could viably be done or not....even using 2.8s it would be a 5.6l v12 with 270hp and 320 ft lbs of torque...would beat a 5.7....interesting when you think about that....the 2.8 actually makes more power per cube than the stock 5.7 tpis did...and 2 3.4s.....a 320 hp and 400 ft lbs of torque 6.8l....a 5.7 wouldn't even touch it...and thats using stock parts, I could see a built aluminum head 3.4 version potentially making 600 hp and 700 torque N/A....
Edit: just realized the water pump on the rear half would be an issue....maybe an external electric one if there is such a thing...
Old Oct 30, 2010 | 06:10 AM
Engine: 3.8, 3.4
Re: Crazy idea...but...2 v6s, 1 v12.....
And yes I know what a modern v8 can do before anyone says it. But this would be unique as hell.....and well....its not hard finding a full 60/6 for under $300. Try finding a complete lsx for under a grand...and aftemarkets parts on lsxs are equally expensive I've noticed.
Old Oct 30, 2010 | 09:43 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Look at how tractor pull guys hook up two or more engines . Basicly you would only need to join two complete engines with a coupler between them and thats it . Run hoses and fuel lines to both and wiring to both and your done . I have seen an article once where a guy combined two VW engines buy cutting them apart and welding them together to make a 8cyl VW and the crank and cam were custom done to work .
Old Oct 30, 2010 | 10:23 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yep, I've thought about it, I even have enough space in my Datsun engine bay to do it.
I'll stick with just a single V6, at least for now.
Old Oct 30, 2010 | 10:39 AM
Stephen's Avatar
Car: 87 GTA
Sure. I've seen 2 V8s merged together to make a V16, so the V12 would basically be the same build process.
Callaway V16 Link
What the tractor pullers do isn't even close to this build. They use separate engines both driving one custom gear box, to transfer the combined power to the wheels.
Old Oct 30, 2010 | 01:29 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I saw one done decades ago in Hot Rod- can't remember who- and I think they put them nose to nose and had one run in reverse or something.... engineering nightmare and marvel all in one!
Old Oct 30, 2010 | 01:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GMC beat you to it... one block, 1 crankshaft, 4 heads, 1 distributor but 2 caps and 2 coils.
Old Oct 30, 2010 | 02:42 PM
Engine: 3.8, 3.4
Alright so I guess it could be done...but where to stuff one...I personally wouldn't want that much of it sticking past the front wheels when using the stock location...
Old Oct 30, 2010 | 03:06 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
ha ha ha ha ha that is amazing
what in the world could you even fit that in
Old Oct 30, 2010 | 03:42 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Small train, a generator, or a tractor.
Put a GMC 478 V6 in your car.
Put a Caddy V16 in your car. (The old one is the only one available.)
Old one
Newer one
The newer one only puts out 1,000 HP.
Old Oct 30, 2010 | 04:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Good for heavy trucks, construction equipment, or nuclear deterrence:
Old Oct 30, 2010 | 08:34 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
The Cadillac 16's engine is just that though, two V8's crammed together to form one engine. And the new one only puts out 1000hp? The old one only puts out 175! At least stock way back then.
Old Oct 30, 2010 | 08:38 PM
Engine: 3.8, 3.4
Engines honestly have not changed all that much over the years, the only new technology I can really think of is vvt, DI, DIS and I suppose you could consider OHC configuration new technology, though tbh they aren't better than pushrod engines, each has their pros and cons.
Other than that its just been tweaks to this and that.
Old Oct 30, 2010 | 09:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Variable valve timing and overhead cams have been around for nearly 100 years now.
What's changed are the design and evaluation tools, and the control systems.
Old Oct 30, 2010 | 09:47 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
There isn't much new under the sun. All this stuff has been tried in various ways over the decades and often times failed and faded into oblivion, anyone remember audi's 'UFO' brakes? I've often thought of hacking up 2 blocks and welding them together. Then the reality of what would need to be done sets in and I put a turbo on something.
Old Oct 30, 2010 | 10:13 PM
Engine: 3.8, 3.4
lol
and could you tell me about those "UFO" brakes??
Old Oct 31, 2010 | 11:58 AM
bl85c's Avatar
Car: '85 maro
They warped easily and sucked. It was supposed to offer better braking in a smaller package. Here's a pic.
Old Oct 31, 2010 | 12:59 PM
Engine: 3.8, 3.4
Yeah i looked it up, supposedly braking from 50-60 mph could help straighten them back out some, that cracked me up pretty good.
Old Oct 31, 2010 | 04:46 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
IIRC each of those sixes are 305cid.
Old Oct 31, 2010 | 04:56 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Its a single V12, not two V'6s together. Total displacement is 730ci. Its the GMC 730 V12. They just took two of everything that fits ontop a V6 and in a V6 and made a crank for it all.
The engine weighed almost 1200lbs with everything in it.
Old Oct 31, 2010 | 05:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you really want a pair of V6's to power your car, figure out how to do a FWD conversion up front, figure out how to get a fiero drivetrain in the rear, and tie the throttles together. It'd be a lot of work, but you'd be a whole more likely to get it to done than you would be to successfully weld two blocks and cranks together.
Old Oct 31, 2010 | 05:08 PM
That's actually kinda neat.
Kinda like combining a drum with a disc. lol
Old Oct 31, 2010 | 07:03 PM
batsibf's Avatar
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
when I saw this I was thinking you could do it but the blocks would have to be side by side with one set of exhaust manifolds (top of the engine) put together with the other set under the engine, I know I'm not describing it well, but the two blocks would be at about 60* turn from normal right or left depends on witch side it would go on, with the oil pan mod so both engines use the same pan. I'll try to get a pic of a Lego motor (once I build it and time off from work) basically the cylinders at the top of the engine would be about 30* of vertical to give room for the exhaust headers.
Old Oct 31, 2010 | 11:41 PM
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
If someone did a motor and tranny in front and back, I would use one of those fly by wire throttle body like newer vehicles use. So it would be easier to control the throttle.
The concept vehicle called the Jeep Hurricane had a a motor in the front and back.
Old Oct 31, 2010 | 11:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could... It's was done for decades with cables before the advent of fly-by-wire though.
Old Nov 1, 2010 | 02:11 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
I believe Volkswagen and maybe someone else builds something similar to what your describing. They call it a W12
Old Nov 1, 2010 | 07:59 PM
Bugatti has the W16.
Old Nov 2, 2010 | 08:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
He's right, I remembered the same article. It was called the "Push me, pull me"- a Citation with a 2.8+transaxle in the front and a second 2.8+transaxle in the trunk.
I found the 1998 Hot Rod scanned pages here:
[edit] Wow, the links went strange so I removed them. Apparently you have to go to the main page first to see them, so, I pulled each link. Go to this main page, then scroll to the bottom and look for the four links titled ""Push Me, Pull Me" 1985 Twin Motor Citation X/11". 2 magazine scans and 2 pictures.
http://www.gt.ppdictionary.com/concept_photos.html
I'll have to go through that dusty old pile of magazines and see if I still have that issue. I don't remember the last two links (the color pictures) being part of the magazine though; I think it was something like a "top 10 GM concept cars" article, not in-depth coverage of the Push-me-pull-me car.
Old Nov 2, 2010 | 11:00 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
yup but I was thinking it was made before '97 ( i missed a lot during the late 80's and 90's sub duty tends to do that)
Old Nov 2, 2010 | 11:27 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
OK So I fixed the links in my first message; I guess you have to go to the main page and view them from there.
Looks like the push-me pull-me X11 concept was auctioned off at Barrett-Jackson:
http://www.youtube.com/watch?v=6Qr3G...eature=related
http://www.barrett-jackson.com/appli...&aid=284&pop=0 Not a bad deal for $15G!
I'm assuming this is the guy that bought it:
http://www.youtube.com/watch?v=YhLAm...eature=related
He's got a few videos up, I'll watch 'em all later.
Old Nov 2, 2010 | 11:57 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
The one I saw was WAY back, decades ago. It was 2 v8s that had one common crankshaft, designed for drag racing I think. This is all mental gymnastics anyway- too much engineering to make it worthwhile. You would have to make some sort of girdle, top and bottom to bolt both blocks together while you had then welded, then have someone make you one each GIANT crank- and camshafts! Actually, short of the machining needed to match the blocks to each other, designing the fuel injection and ignition systems, that would be the only major problems... OH YEAH, then there is getting it into the car, having a trans that could take the power and not to mention it would weight about TWICE what a tricked out LS6 would and probably make less power! Be fun if I win the lottery, although I think aluminum V6 blocks would be a better starting point...
Old Dec 17, 2010 | 03:33 AM
Zeeboinc's Avatar
Car: '89 Iroc Z
Engine: Paxton SN-92 305
Transmission: 5 spd
There's a twin engine twin turbo tiburon out on the net too. Its basically two turbo 4 bangers (one up front and one in the what used to be a trunk). Does sick 4 wheel burnouts. You can check it on youtube. I'd post a url but this damn government comp keeps blocking all the good sites on me
Old Dec 31, 2010 | 09:05 PM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
A friend/family member of mine did this: http://www.engineswapdepot.com/?p=915
He used a steel & rubber coupler to connect the two. It's fun as hell when he whomps on it! PM me if you are interested in the coupler.
Old Jan 1, 2011 | 03:43 PM
bl85c's Avatar
Car: '85 maro
I remember seeing that in hotrod magazine. Bet it sounds wicked!
Old Jan 2, 2011 | 03:23 AM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
http://www.youtube.com/watch?v=VfswV...eature=related
Old Jan 2, 2011 | 02:04 PM
bl85c's Avatar
Car: '85 maro
Ohhh, that was sexy. The view out the rear window is great lol.
Old Jun 6, 2012 | 11:24 PM
Mr.Franco's Avatar
Car: 1992 Camaro
Engine: TPI 350ci
Axle/Gears: 3:73
http://w.ivenue.com/hendrixengineeri...t-coupler.html
Driveshaft coupler can dampen vibration and should be able to take the torque. Couple the front of one motor to the back of the other. Just make sure your at TDC on both motors before ignition.
Old Jun 9, 2012 | 08:36 AM
83Berli's Avatar
Car: '83 Berlinetta
Engine: 2.8L V6
Transmission: 200C
That looks pretty sweet, someone makes some real bank to afford the gas. You know he isn't running 93 octane in that thing.
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
