Supersix Motorsports
Old Nov 9, 2010 | 08:45 AM
overide's Avatar
Supersix motorsports porting... good / bad? Anybody have bench flow numbers for them? I contacted them directly, but they don't have the data anymore on the 3.4L iron heads. I have a set of 3.4 heads that were already ported, but I'm considering having them bench flowed to be sure they are maximized. I just don't want them to be the massive bottleneck in the system. I have a friend who lives around Supersix's area, so I thought I might run them down there & see what they can do. I wanted someone who knows these internals to go over them and see if they can be taken further. That and I would not mind someone going over the lower intake.
Are they a good choice or is there someone better?
Old Nov 10, 2010 | 08:01 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Supersix Motorsports
Honestly if you're that concerned about head flow you should go to aluminum heads....because all other things built up, the iron heads ARE going to be the bottleneck...aluminum 3x00 fwd heads stock outflow the best ported iron heads possible, and since you have a 3.4 the swap is easier than a 2.8 or 3.1, because your engine is already setup to run DIS, just my 2 cents, imo keep the porting you have and use that money you would have spent on a high end shop to start getting things for a hybrid build..
its pretty much what I'm doing...I built my engine up with iron heads, but once the rest of the car is up to par I'm going to build it again as a hybrid...I need to rebuild the lower end still anyways, 140k on my block and rotating assembly, top end is rebuilt so pretty much new..and all that said, I have no idea if supersix is any good or not, haven't heard of them but its not like I make it a point to know about speedshops either, I do know that for aluminum head porting WOT tech while expensive probably has the best stuff to offer.
Old Nov 10, 2010 | 09:03 AM
overide's Avatar
I will probably cave to the superior flow of the 3500 heads at some point, but since I already have my heads done...they have been sitting a bit, started this before the hybrid craze... I was hoping to have them looked over by someone I could get them to. Really I just want them flowed
Old Nov 10, 2010 | 09:05 AM
Engine: 3.8, 3.4
Imo do what I did, just bolt them up knowing they're better than they were and don't worry about just how good they are, because you know you're going to get something even better.
Linson
Oct 1, 2015 09:50 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
vortech305
Aftermarket Product Review
Jun 1, 2001 06:49 PM
Jester
Apr 23, 2001 12:22 PM
