Planning on nitrous
Old Jan 20, 2011 | 06:59 PM
  #51
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Planning on nitrous
Originally Posted by Killert
Ignore the white hose on the intake, that was for a ghetto purge I setup before I sold the solenoid and also ignore the unhooked up mechanical temp gauge.
Ohh though plz rip down that nasty hood linner, after 10-15 years they become nothing but a fire hazzard as they collect dust and grime.
Get a new one if you must have it.
And get a new cowl seal or make one, your fresh air duct will be sucking under hood fumes. I made a new one out of thick weather stripping foam, 2 layer thick peel n stick kind.
And you got allot of fancy electronic along with hi power carrying stock relays in that corner, you don't want rain water just rushing down over everything. The stock seal acts like a dam and make it go backwards and out the fender drain.
Old Jan 20, 2011 | 08:32 PM
  #52
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Originally Posted by AmorgetRS
I have no problem driving my V-6s and trust me, I have PLENTY of V8 options to drive.
I'd also never buy a V6 to V8 swap car, in my eyes it halves the value of the V6 car, especially if they did a EFI to Carb swap in the process.
What about V6 to LSX?
Old Jan 20, 2011 | 08:49 PM
  #53
AmorgetRS's Avatar
At that point the only value the car has is the LS motor and the swap stuff, and at about a 50% return rate, any other aftermarket part they put on the car.
I'd never buy a LS swapped from a V6. Anyone who has enough brains and $$ to do a LS swap right has the brains and $$ to start with a V-8 car.
Old Jan 20, 2011 | 09:09 PM
  #54
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
http://www.kingomatic.com/documents/...o%20111208.pdf
Page 15 has stuff for our motors. Spline count and what not. I'm looking at a GM61HD which I can get a Advanced Auto Parts for 110$
Old Jan 20, 2011 | 11:28 PM
  #55
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Not unless you make it a mid engine.
Old Jan 21, 2011 | 12:04 AM
  #56
Car: 1989 Camaro RS
Engine: LH6
I don't see the difference, they are the same car, just either one has different motor and some IROC-Z or Z28 decals (basics, not going in depth). Or is the same car, just has a TBI V8 in it. If your doing an LS swap in these cars your obviously not looking to get your money out of it, your looking to do it for your enjoyment, so weather it's a V6 car or V8 is doesn't matter.
Old Jan 21, 2011 | 11:52 PM
  #57
Bill B's Avatar
Car: 91 camaro convertible
Engine: 355 c.i.
Transmission: auto 700R4
Axle/Gears: 3.90 moser 12 bolt
Why is that ? as long as it wasnt a hack job whats wrong with a V6 to v8 conversion carb or efi
Old Jan 22, 2011 | 12:37 PM
  #58
AmorgetRS's Avatar
All those details you talk about are why
The carb conversion because you reduce gas mileage and driveability for the sake of "laziness". IMHO, there is no such thing as a Thirdgen efi to carb conversion that is not a hack job.
EFI, because it would of been cheaper for them to buy a V8. I don't trust anyone who has more money then brains to do it right. Plus, even if it doesn't look like a hack job (I personally haven't seen one that didn't look basically like hack) there are tons of things that are different between the V6 and the V8 cars (suspension, steering, etc) that they probably didn't replace and who knows what wiring nightmares might hide in the harnesses.
It's buying someone else's problems 99% of the time, and that 1% I wouldn't be willing to risk when I can buy a running V-8 TPI 5 speed car with under a grand.
Old Jan 22, 2011 | 05:12 PM
  #59
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Where can you buy a running v8 tpi 5speed car for under a grand without it being a complete run down POS and a waste of time?
Old Jan 22, 2011 | 05:13 PM
  #60
Bill B's Avatar
Engine: 355 c.i.
WOW so everybody thats ever put a V8 carb motor in a v6 3rd gen is a lazy hack.
I guess everybodys entitled to an opinion and a attitude.
Old Jan 22, 2011 | 07:23 PM
  #61
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Well, Back on topic. MY alley where my garage is is too iced to get my car back there. I'm gonna back the timing to 10* so I can put on the 100 shot. On Monday I might be able to do it at school.
Old Jan 22, 2011 | 07:29 PM
  #62
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Just 1 bolt and a small twist. Can't do that on ice?
Old Jan 22, 2011 | 07:51 PM
  #63
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Its not the ice that bothers me, Its the not being able to stop :-p.. and the lack of traction to go uphill into the garage haha
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Zell1luk
Sep 29, 2015 10:36 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
