check engine light?
Old Dec 30, 2010 | 07:01 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
check engine light?
hello all, my check engine light comes on after iv been driving the car for about 5-10 minutes, all my gauges seem fine, besides my temp gauge it still doesnt work because i havent put in a new temp sending unit yet but i stil have hot air so i know im not over heating, after i turn the car off and restart it its gone till i start driving again, but after i restart it comes back soon like around 2-3 minutes, so im lost on whats causing this, if anyone can add some input i would appericiate it
Old Dec 30, 2010 | 07:19 PM
Drew's Avatar
Re: check engine light?
Check your codes.
Old Dec 30, 2010 | 08:54 PM
Engine: L31 350
i have..can i get them while the cars running?
Old Dec 30, 2010 | 08:57 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
sounds like one of your EGR system vacuum hoses has broken or come loose... look really really closely at every hose
codes are checked with the car off, but the key is in the on position
Old Dec 30, 2010 | 08:59 PM
Engine: L31 350
when the cars off i get no codes, only 12 which is normal, will that vacum hurt anything to keep it driving till spring?
Old Dec 30, 2010 | 09:00 PM
58mark's Avatar
when it happened to mine it seemed to drive normally, but open vacuums should not be ignored. Do yourself a favor at at least get under the hood with patience and a good flashlight and looks at everything... be patient, you'll find it
Old Dec 30, 2010 | 09:11 PM
Engine: L31 350
wheres the egr at? its near the back of the engine right? pasenger side?
Old Dec 30, 2010 | 09:15 PM
58mark's Avatar
passenger side. do a search for it on autozone.com to see what it looks like
don't check jsut the hoses running right to it. there are a ton of hoses on both sides of the engine that all draw a vacuum
not a great pic, but it's that little black disc between the plenum and the dryer
Old Dec 30, 2010 | 09:18 PM
Engine: L31 350
i cant see it mark, can you circle it please.
Old Dec 30, 2010 | 09:23 PM
58mark's Avatar
Old Dec 30, 2010 | 09:28 PM
Engine: L31 350
all those vac lines are on, iv checked those.
Old Dec 30, 2010 | 09:30 PM
58mark's Avatar
I still think you have one somewhere that's cracked...
I'll look in the troubleshooting guide in my service manual. Were you at highway speeds when the light first came on?
Old Dec 30, 2010 | 09:31 PM
Engine: L31 350
bout 30, i was only in town, and its a small town at that
Old Dec 30, 2010 | 09:40 PM
58mark's Avatar
I can't seem to find the section i'm looking for, but I do know that another thing that can cause the ECM to not store a code is a problem with the fuel filter. When it happened to me I felt a little dip in power and the light flashed
Old Dec 30, 2010 | 10:54 PM
Engine: L31 350
i dont feel a dip in power, i mean it shifts alil late into second but thats it, but im also a new driver in a new car so i might not notice it
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
