exhaust headers
Old Jan 7, 2011 | 09:42 AM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
exhaust headers
my engine is ticking n a mechanic said it was a manifold leak .. considering my exhaust isnt stock im going to assume the person before me loosened the manifold n didnt tioghten it. or the bolts r loose.. where are the bolts for the manifold.. pics would help. i cant find any
Old Jan 7, 2011 | 08:45 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: exhaust headers
Uh... what?
Old Jan 7, 2011 | 11:26 PM
Axle/Gears: 3.47
Re: exhaust headers
u know how the air pump pumps air into the exhaust pipe? well if u get aftermarket headers.. the pump is useless.. well i was thinking . is it possible to hook up a turbo to that instead of hooking it up to the header pipe.. but someone said its not strong enough to power the turbo
Old Jan 8, 2011 | 01:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: exhaust headers
Dude, just ditch the AIR pump unless it's mandatory you have to have it. It's a waste of metal and weight, and if you ditch the factory manifolds, it's almost completely useless (can only send air to the converter).
Let's put it this way, even a leaf blower is too weak to run a turbo, and the AIR pump is no leaf blower.
Old Jan 8, 2011 | 10:38 PM
Axle/Gears: 3.47
Re: exhaust headers
understand.. n i live in jersey.. emissions sux so i think its mandatory
Old Jan 9, 2011 | 01:36 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: exhaust headers
One thing you might check is that some areas within states require and some don't...i used to live in somerset, pa and didn't need them, when i moved to pittsbrugh(one of the two biggest cities by far, think it even is the biggest) every town around here requires them.
Old Jan 9, 2011 | 07:56 AM
Axle/Gears: 3.47
Re: exhaust headers
how badly will emmisions be with it removed.. is it significant?
Old Jan 14, 2011 | 01:21 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: exhaust headers
My car was originally from new jersey and doesn't have the AIR pump and always passed emissions.
Old Jan 17, 2011 | 07:44 AM
Axle/Gears: 3.47
Re: exhaust headers
i myself am having emission problems as it is.. even with the air pump.. i have no clue what to do.. the plugs are fine. its got a new fuel pump.. timing is set to 9... should be ten i know.. i wonder if the prvious owner hollowed out the cat.i have no other ideas
Old Jan 17, 2011 | 08:56 AM
Engine: 3.8, 3.4
Re: exhaust headers
your egr could be bad, or even just a vacuum hose.
Old Jan 17, 2011 | 11:53 AM
Axle/Gears: 3.47
Re: exhaust headers
check engine light off fixed a vaccume hose to it.. i wonder how many vac hoses there are in this vehicular
Old Jan 17, 2011 | 12:07 PM
Engine: 3.8, 3.4
Re: exhaust headers
The short answer-too many. I for one hardly have any....but my car would def not pass a smog test...for that reason I think I will have it inspected where I used to live, because I honestly don't want to have all that emissions crap hooked up anyways.
Old Jan 17, 2011 | 12:22 PM
Axle/Gears: 3.47
Re: exhaust headers
ugh
Hotrodboba400
Dec 10, 2019 07:07 PM
bamaboy0323
Sep 12, 2015 07:14 PM
89fast5oh
Sep 8, 2015 09:55 AM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
