Camaro rs v6 3.1 1992.. fuel pressure?
Old Jan 9, 2011 | 08:20 PM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
Hi...
Some knows what's the pressure of a fuel pump of a camaro rs v6 3.1 1992...
how much it needs to open the inyectors...?
thanks..
Old Jan 11, 2011 | 11:26 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Camaro rs v6 3.1 1992.. fuel pressure?
it should have 43 psi with the pump primed(ie. you turn the ignition on but not the engine) and it should drop about 10 psi or so while running if memory serves.
Old Jan 11, 2011 | 05:50 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
37-47 PSI pressurized and not running for 20 minutes. Any loss of more than 1 PSI in 20 minutes means a leak. Running pressure should be 4 PSI less than non-running pressure.
Old Jan 11, 2011 | 06:56 PM
Engine: 3.8, 3.4
only 4? haynes manual said something to 10, not that i trust my haynes as far as I can throw it.
Old Jan 11, 2011 | 06:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I believe it's 3-5, actually. Still, Haynes is only good as toilet paper in an emergency and fire starter. And if you don't have anything else and can't afford anything else.
Old Jan 11, 2011 | 08:11 PM
Engine: 3.8, 3.4
Nah, its also good for putting out fires,lol best use i ever got out of it-emergency manual fire extinguisher...
Old Jan 11, 2011 | 08:34 PM
Engine: 2.7L V6
Axle/Gears: 4.41
LOL... I couldn't do that with mine... It's seen too much time in the garage (back when I needed the torque specs) and it's too greasy now. Can anyone say "flash fire" ?
Old May 6, 2011 | 10:29 AM
fitojdj's Avatar
Thank you Guys..ĦĦĦĦ
Fireslash
Apr 11, 2016 06:43 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Dragonsys
Sep 25, 2015 03:51 PM
