Tranny Mount???
Old Sep 24, 2000 | 03:16 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Tranny Mount???
last wwek i hit a dip really hard and saw sparks fly out from behindme.. Lately i notice when i go to accelerate at half throtle i hear somethin pop near my tranny it sounds liek the tranny mount but im not sure lasttime it went it was loud and jerked the whole car during shifts... How can i go about finding out about if it is that and also how do u go about replaceing it with it is... if it is im gona use polyurthane ones insted of the crappy rubber ones
Old Sep 24, 2000 | 12:02 PM
Gunmetal's Avatar
Take a crow bar of some sort, jack the car up and insert the bar in between the tranny and the crossmember. If you see the chunk of rubber seperate at any spot than it is shot. Also check and see if there are any cracks. Replacing is easy, 4 bolts that hold on crossmember, 2 bolts from member to mount and 1 or 2 bolts to the tranny. when you tighten it, torque them all to 35 ft lbs. Also if they are not coming off easy. I would suggest heating them up with a torch. I busted one of my crossmember bolts in half, it cost me 50 bucks to have it taken out. That may or may not happen to you.
'88 bird 2.8 T-5, 3:42, K&N, Cat-back
Old Sep 24, 2000 | 02:54 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
easier method:
powerbrake the car...if theres a thud, ur mount is broken.
Old Sep 24, 2000 | 02:57 PM
FAST RS's Avatar
So i take off the whole cross member and everything off then tale the mount off correct???
is there a TECH article on it by anychance
Old Sep 24, 2000 | 05:08 PM
foo02's Avatar
If you have a 5-speed v6, be prepared to pay like 150 for a mount.
Unless, you can find a v-8 crossmember cheap and go buy the mount for a v8 auto, that was cheaper in my case and seemed to work perfectly.
Oh, also, a similar sound happened to me when i knocked my torque arm loose at the trannie....sounded like a hammer under there banging around when i would accelerate.
~Sp33d~
(sold)1989 2.8l 5-speed RedBird w/ flowmaster, cold air intake, TRW cam. Audio system includes-Cadence component plate 4x6's/Cadence 3way 6x9's,300watt amp to front speakers/400watt to Blaupunkt DVC 12" sub.
[This message has been edited by foo02 (edited September 24, 2000).]
Old Sep 24, 2000 | 05:27 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
150 for a tranny mount? christ i can get a complete steel mount set (motor and trans mounts) for not even half of that.. chances are if your hearing that noise its broken, jack the car up, and put another jack on the bottom of the tranny (not the pan) and jack it up a tiny bit to get the mount off.. two bolts hold it to the tranny, and theres a stud on it that goes thru the crossmember if i remember correctly...
Old Sep 24, 2000 | 07:43 PM
FAST RS's Avatar
The crosmemeber is the thing that goes like in the center of the tranny and holds it up right???? cuz i think i coula knoked it loose since i hit that dip relaly hard the other day also ive noticed my oil pressure has gone up since i hit that dip also
Old Sep 24, 2000 | 07:58 PM
Gunmetal's Avatar
The crossmember is what u see first. Its about a foot and a half long. it looks kinda like a peice of frame for the car.
Old Sep 24, 2000 | 08:00 PM
Gunmetal's Avatar
Take a crow bar and put it above the crossmember, but under the tranny. now pry up an the transmission and look at the mount at the same time to see if the rubber is torn or coming apart.
Old Sep 24, 2000 | 08:01 PM
Gunmetal's Avatar
If you have an auto the mount will be about 8 bucks. If you have a manual then it will cost about 150.
Old Sep 24, 2000 | 08:04 PM
Gunmetal's Avatar
Now if this process doesn't work, (the crowbar) then take the cross member off.
Just put a jack under tranny, then jack it up until it looks like weight is taken off the mount. then undo the 4 crossmember bolts. And then you can see the mount, and be able to tell, if it is torn or cracked i would suggest replacing it. I would get a polyurethene too.
Old Sep 24, 2000 | 08:07 PM
Gunmetal's Avatar
oh by the way, did you crunch in the oil pan when you hit whatever you hit? you may have messed up oil pickup unit, i don't know though, mine did that same thing after I hit a rock, a big rock.
Old Sep 24, 2000 | 10:17 PM
FAST RS's Avatar
My pan looked perfectly fine... so i dono but isnt increased oil pressure good
Old Sep 25, 2000 | 05:23 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
you needent remove the crossmember to replace the mount.. yes, the cross member runs from either side of the unibody directally under the tranny, where is runs under the tailshaft there is your mount.. just jack up the tranny a bit and look at the mount, its easy to tell.. as far as your oil pressure going up after you hit that bump, im not sure, but even if you dented your oil pan, that wouldnt make the pressure go up.. although all i could think of is you stired up some crud with the bump and it got caught in your filter and made the pressure go up.. (damn i forget if the sender for the gauge is before or aft of the filter)
Old Sep 25, 2000 | 05:27 PM
FAST RS's Avatar
Im just gonna tqake it to my mechanic tommow considering my fron brake are GONE and i think i have a bad bearing in my engne not sure were soo i figure ill have him do it while im there.
Also i did do an oil change and still no difference in pressure
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
