ok guys, please clear this up
Old Sep 26, 2000 | 10:48 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
ok, is the 3.1 a bored 2.8 or a stroked 2.8??? i've heard both but i think it is a stroked 2.8. dunno???
Dan
100% stock 1990 RS 3.1L
and VERY slow
Old Sep 27, 2000 | 01:08 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
All it has is a bigger crank ive herd
Old Sep 27, 2000 | 01:12 AM
Engine: LH0 3.1L
that'd be a stroker then. my next question....is the 2.8 block identical to the 3.1??? for example: main seals, crankshaft journals???
Dan
and VERY slow
Old Sep 27, 2000 | 12:58 PM
RenoLB8's Avatar
In all respects, they should be identical, as with the 3.4. I've heard there is a slight difference that can be ground out on the journals though.
Reno
'88 Firebird LB8
"Cerberus"
Now: rusting on a side street til I get out of college
Plans: BUILT 3.4 motor with B&M racing tranny, Hotchkis suspension all around, lowering 1", Accel ignition all around, Splitfire plugs, 88 front bumper, ASCD Ram Air I hood, 91 GTA spoiler, formula wheels, Firehawk tires, restored interior (first on list)
Old Sep 27, 2000 | 03:15 PM
Engine: LH0 3.1L
thanks reno
Dan
and VERY slow
Old Sep 27, 2000 | 06:43 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
the 2.8 3.1 and 3.4 blocks are all the same with the exception of each has a bigger bore than its predecessor..
Old Sep 28, 2000 | 02:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is the 3.4 block's external dimensions the same as a 2.8's? I thought a 2.8 couldn't be bored out to become a 3.4 because the walls got too thin.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 28, 2000 | 07:55 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
Tom, did you get that info off that old board that had all the mods for the 60 degree v6. I think they said something about boring the engines, and said that once you got to 3.4 litres, you were way in the danger zone. But, i'm sure Chevy could have devised a way.
Old Sep 28, 2000 | 09:48 PM
3.1 firebird's Avatar
I;ve read where the 2.8 and 3.1 have the same 3.5 inch bore, but the 3.1 has different pistons and crank. The 3.4 has a 3.6 inch bore. You can bore a 3.1 about .040 or .060 over , cant remember which, and come out to a 3.2. Nick Norris said his 3.4 heads will work on 2.8/3.1's and my 3.4 headers fit my 3.1, so I'd say its safe to say the heads are about the same( except 3.4 heads have the big valves).
Old Sep 29, 2000 | 12:02 AM
Engine: LH0 3.1L
so if you were to build up a 2.8/3.1....would you recommend stock 3.4 heads?? does anybody make performance heads for a 2.8/3.1???
Dan
and VERY slow
Old Sep 29, 2000 | 12:39 AM
RenoLB8's Avatar
2.8
3.1 = stroked 2.8
3.4 = bored 3.1
3.4 = stroked and bored 2.8
Got it?
Good.
-Reno
Old Sep 29, 2000 | 03:14 AM
but......you cant bore a 3.1 to a 3.4. You'd have to bore it .1 over! you can only safely bore a 3.1 .040-.060 over tops. The 3.4 block has a little more iron aound the cylinders.
Old Sep 29, 2000 | 08:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
85f-bird, I don't know what website you're talking about, never saw it...
3.1Firebird, how'd they swing that then? Is the 3.4 block bigger externally? Or did they make the water jackets smaller? Hehe, someone's gotta cut open a 3.1 and 3.4 block!
Also if the 3.4 heads have bigger valves, can the 2.8/3.1 heads be modded to take those same valves? Oh wait then the motor'd probably need extra fuel... AFPR? Woah.
Old Oct 1, 2000 | 12:03 AM
Dan84SC's Avatar
http://www.foothill.net/~terryk/X11Z19.HTM
The 2.8L and 3.1L share the same block, (except for earlier 2.8Ls that had smaller main journals), and a 3.4L block is a beefed up version of a 3.1L with a slightly larger bore.
Read all about it at the URL above. Very good basic info on our engines.
aaron7
Aug 17, 2016 06:02 PM
evilstuie
Feb 28, 2016 03:33 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
