Swapping out FI for Carburator
Old Sep 20, 2000 | 12:22 AM
JASONCOX's Avatar
I'd like to know how difficult it would be to install swap out my fuel injection setup for a carburator. How much would it cost and how much time does it take???? 2.8L V-6 MPFI
Old Sep 20, 2000 | 07:52 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
why? just curious. Remember the old 2.8's with carbs didn't put out as much as our FI's, but if you do it, make sure you get the hi-performance carb, and not a stock one.
Old Sep 20, 2000 | 08:23 AM
Brian K's Avatar
WHY???? If I was going to make that change I would get the Edlebrock Manifold, and Holley 4 Barrel that fits it and make sure I kept the eletric fan and ported the heads so hopefully it would be faster.
Old Sep 20, 2000 | 05:39 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i neer understood why people wanted to go from FI to carb, especially on engines as small as ours.. youd lose so much power it would be rediculis, if your 2.8 fbod has too much power, drop in a 2.5l iron duke motor for about 90 some hp at the rear wheels..
Old Sep 30, 2000 | 01:06 PM
MILT's Avatar
Remeber, you would also have to get a non-computer controlled distributor. After adding up the costs, it really wouldn't be worth it...
Old Sep 30, 2000 | 11:41 PM
Dan84SC's Avatar
Eh... It would be EASIER to make power by ripping out the POS computer and FI, and slapping that Edelbrock 4bbl intake and a Holley 390cfm 4bbl carb.
Wouldn't even come close to being emissions legal, though. No EGR system on that intake...
I've thought long and hard about whether I should stick with a carb setup, or switch over to some form of FI. If I switch to FI, I'm going to go with an SFI setup, not MPFI. No distributor to worry about, just a crank trigger, and three coil packs.
Blah... Talk to someone who's had that intake and carb. They're worth it for cheap power that's easy to maintain.
Old Oct 2, 2000 | 10:17 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's probably just me, but I'd rather have the distributor than the coil packs & crank trigger. I can rebuild my distributor for $80...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 3, 2000 | 09:49 PM
GOLD85's Avatar
befor i threw the 8 in my car i once contemplated put a edelbrock manifold, edel cam,headers, and a 390 cfm holley, 4:10 and some posi, do up the heads, get every thing ballanced, it would be so cool, but i put a 8 in and could beat the pants of any suped up 6 banger third gen
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
