fuel.. again!
Old Jan 26, 2011 | 07:33 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
fuel.. again!
fuel pump isnt working.. fuel relay isnt turning on.. all fuses under dash are good.. someone said that there are 2 fuses under the hood. i cant find them at all.. there supposedly by the battery. i cant find any of them for the life of me.. is there any way someone can show some pics of what/where they are.. im running out of ideas..
Old Jan 26, 2011 | 07:54 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: fuel.. again!
they have a cover on them, on my 88 2.7, there were 2 on the passenger side under hood, kind of by the air cleaner, there are these small black things, that seperates from the fuse holder.
Re: fuel.. again!
the fuse isnt visible, you have to seperate the cover form the holder
Old Jan 26, 2011 | 08:09 PM
Axle/Gears: 3.47
Re: fuel.. again!
the only fuse i see is a black tube tht i unscrew and a small tube fuse is there but it looks like it goes to a system thats used to be in the car(audio) i dont see any other fuse holders.. any way i can get a picture?
Old Jan 26, 2011 | 08:19 PM
Axle/Gears: 3.47
Re: fuel.. again!
nvm i found them... the fuses are good.. well the metal is.. one of them the plastic is warped.. but the innerds are fine...
ownor
May 18, 2014 06:21 AM
92RS_T-Top
Jan 10, 2012 03:53 PM
Kevman
Sep 6, 2010 05:47 PM
DHo
Apr 22, 2010 06:20 AM
