Horn Not Working
Old Oct 22, 2000 | 10:57 PM
KNGHTRYDR's Avatar
Horn Not Working
My horn is not working at all. The previous owner had a problem with the factory alarm, but where do I look as far as where to reconnect the horn if it was disconnected?
Old Oct 23, 2000 | 12:40 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
open the cover of the steeringwheel carefully at the ends, bent the ends where the hornmarks are than check the small plastic connectorclips, they sometimes brake in parts if you hit your horn to hard. I had the same prop. but I started surching from the other end.
Horst
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax muffler
Old Oct 23, 2000 | 12:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well the horns (2, connected to each other, one=high freq, one=low freq) themselves are on the upper frame rail, on the driver side. They hang "inside" the fender. Look for a single green wire.
If the horns are connected to the wire, you could probably unhook the wire, and connect a test light (or voltage meter) between it and ground. Then you could hit the horn button and watch for a light (or meter swing) to make sure the horns are getting power.
I think the horn relay itself is in the courtesy center, that's located above the driver's feet. Remove the black "hush panel", and look up, past the passenger side of the column. There's a black rectangle there. You squeeze two "side clips" and pull down, the front swings down to reveal the stuff on top. Remember I said "I THINK" that the horn relay's in that spot!
Either that or the contacts for the horn button are dirty. Hell the horn button might be unplugged; it's one single wire under the button. If I remember right, the horn button just pops up with a screwdriver on a Firebird.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
