VACUUM ISSUES??????
Old Oct 22, 2000 | 10:15 PM
KNTRDR's Avatar
VACUUM ISSUES??????
I NEED SOME DIRECTION ON WHERE TO GET DIAGRAMS TO REPAIR/REPLACE ALL VACUUM LINES AND SENSORS. I WAS TOLD I NEED THE EMISSON REGULATION CODE FROM STICKER ON HOOD. ITS NOT THERE, IT GOT JACKED DURING BODY WORK. IT WOULD BE SWEET IF SOMEONE COULD EMAIL IT TO ME. CAN IT BE FOUND IN HELMS MANUAL? IVE GOTTA GET THAT THING. ANY HELP IS APPRECIATED. THANKS
Old Oct 23, 2000 | 12:26 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Well, for starters...QUIT YELLING!!
Second...What year/engine combo are we working on??
Try your local library, they seem to have great selections for wiring/vac. diagrams
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 23, 2000 | 12:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Also, if the car's already hooked up and there's been no underhood fires, you could probably just pull & replace as you see fit...
The biggest vaccum lines on the 2.8 come from the back of the plenum, one goes to the brake booster, and one goes to the vacuum tank.
The rest, if I remember correctly, come off the back of the throttle body, and hit the EGR system, fuel regulator, and charcoal canister.
If you had a carbeurator that'd be a totally different story (and a mess! )
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 23, 2000 | 10:12 PM
KNTRDR's Avatar
SORRY ABOUT THE INCOMPLETE INFO. SHE IS AN 89 2.8L RS. TOMP, YOU ARE RIGHT ABOUT THE MAIN LINES, ALTHOUGH I FOUND THE LINE GOING INTO THE CAR FOR AC/HEAT STUFF TAPED WITH ELECTRICAL TAPE TO OTHER LINES. DONT THINK THAT WAS FACTORY?? THIS IS THE MOST AGGRIVATING THING IN THE WORLD, I THINK
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
