The pain of an oil leak
Old Oct 21, 2000 | 11:40 PM
MikeysLil86camaro's Avatar
Ok, I put my car on the ramps, and I found where Im leaking oil from. i either have a defective pan, or i have a defective pan gasket, or both. I am going to change both, becuase neither is pricey. and just hope for the best. Is doing this going do be a big project? The exhaust is right directly under the oil pan. Could somebody tell me how I can do this? Is this something I have to have done professionally, or will I be able to do it myself?
1986 Camaro Sport Coupe MPFI V6
Current Mods: 2K&N Air Filters, ACDelco Rapidfires, new distributor cap and rotor.
"I always get compliments on how pretty my backend is..."
Old Oct 22, 2000 | 11:28 AM
Kevin S's Avatar
It is something you can do yourself.But it won't be easy.
Just behind the catalatyc converter there is a flange with two bolts and a hanger.Remove those bolts and unplug the O2 sensor.Where the exhaust manifold and the y-pipe meet,there are two bolts on each flange.Remove them.The exhaust will drop down out of the way(as long as the car is up off the ground).
Remove the bolts that hold the motor mounts together.This will allow you to raise the engine so the oil pan will clear the cross member and give you some room to work with.
I am about to do this because I bottom'd my RS and dented the pan.I have a slow leak around the drain plug now.DAMNIT!
The only problem you may have is clearing the oil pump pick up tube.
Does anyone know if the oil pan has the splash gaurd(or whatever it is called) inside or is it all open?
When we pulled my 2.8 apart I didn't pay any attention to this.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited October 22, 2000).]
Old Oct 22, 2000 | 09:24 PM
KNTRDR's Avatar
YES IT DOES HAVE THAT DAMN THING THAT GETS IN THE WAY BEST I CAN REMEMBER. IWOULD NOT RECOMMENED DOING THIS TASK BY YOUR SELF. YOU DEFINATELY HAVE TO JACK UP THE MOTOR. IT GOES HIGH ENOUGH THAT IT LOOKS LIKE YOU HAVE A BLOWER HANGING OUT OF THE HOOD. MAKE SURE THAT THE HOOD IS RAISED BEFORE YOU START. I HAD A GM PERFORMANCE MECH DO MINE AND HE REGRETED THAT HE TOOK THE JOB. IT SUCKED. GOO LUCK WITH THE CHANGE.
Old Oct 22, 2000 | 10:31 PM
Kevin S's Avatar
DAMN!!!!!That sucks
http://v6fbody.com/
Old Oct 23, 2000 | 11:01 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Not to be an *** , but if it's oil down the back of the motor, are you sure it's not the o-ring around the distributor shaft?
Before I replaced my y-pipe, I soaked the manifold-to-y-pipe flange bolts with Liquid Wrench for about a week straight.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 23, 2000 | 11:12 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As Tom stated above, check the dist. O-ring....big problem on 2.8s.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
