what would happen if i put a fan on the air sensor?
Old Oct 24, 2000 | 06:21 PM
Dellz's Avatar
what would happen if i put a lil fan like a processor fan on the air sensor? .. that i took out of the air box when i removed it
hmm
Old Oct 24, 2000 | 09:40 PM
Monkie's Avatar
I would say the air/fuel mixture would be off. Maybe causing the engine to run rich???? Anyone else?
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Oct 24, 2000 | 10:08 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
On the LS1 engines you can put a 4.7 ohm resistor between the terminals of the sensor.
This gives the ECM the info that the air charge is colder than it actually is.
This allows the ECM to give a little more fuel/timing curve.
I personally don't think this mod is worth anything noticeable as far as performance goes. Some people say it is, I did it and took it back out. To each his/her own.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 25, 2000 | 04:27 PM
Monkie's Avatar
Do we have a LS1??? Hold on let me go check........Nope we sure dont! Damn.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Oct 25, 2000 | 05:46 PM
Dellz's Avatar
Heh i was thinking the same thing what about the 3.1? hmm would that work?.. ehh
Old Oct 25, 2000 | 10:34 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
OK Monkie....Ha ha...
What I was saying, maybe I should be a little clearer.....was that we used a 4.7 ohm resistor in the LS1, I don't know if the resistor amount is the same on a 3.1.
I wasn't thinking you had a LS1 (DOH!!)
I just didn't know if the resitor value was the same.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 25, 2000).]
Old Oct 26, 2000 | 05:31 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
wow this topic seems about as good, as the old Almighty Deckercharger!!! jk.
Old Oct 26, 2000 | 06:21 PM
Monkie's Avatar
Engineboy sorry about that but I didn't really know what you were talking about. I mean I didn't know if I was right or wrong but I didn't think our cars were much at all like the LS1s. I WISH THOUGH!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Oct 26, 2000 | 07:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Thats cool
The 3.1s aren't like the LS1 but alot of performance upgrades apply to both engines (all engines) in the same ways.
85F bird....."Deckercharger" ???
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 26, 2000 | 08:09 PM
Monkie's Avatar
I dont know about yall but I find it to be a HUGE *** BITCH to find mods for my 3.1!!! Other than the basics I cant find any.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
Old Oct 26, 2000 | 10:34 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
The deckercharger if i remebr correctly was a leafblower turned into a supercharger still wana try it lol it would be frekin halerous. But i was at a page a while back sayin if your moved your IAT to a cooler spot you would gane throtle response. When i get around to it ill try it just dont know were i can put it...
Old Oct 27, 2000 | 07:50 AM
85f-bird's Avatar
Engine: 2.8L, LS1
you're right Fast RS, but hey, i thought it'd be funny as hell to do, i just have to much pride to do it to my car. I think that the entire v6 board should purchase one car, an old 2.8, and then try all types of different mods on it to see what happens, before we screw up our cars.
Old Oct 27, 2000 | 08:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A fan placed over the MAT sensor won't help at all. It's not like the MAT gets hot, like an engine's radiator, or like a computer's microprocessor.
If you were mounting the MAT in a "hot" area, and blowing air from a "cool" area towards it, then yes, it would work. However, why not just hang the MAT in a cool area to begin with?
Here's something interesting to note: The GM/Helms service manual for my '86 Firebird mentions that the "MAT compensates the MAF." It doesn't go into further detail on that statement, however, I imagine that the MAF sensor uses the MAT's reading (of air temp) to use for decoding air flow. Hot air would be less dense, and maybe the MAF needs to know this?
If I remember, on Monday, I'll bring in the chart that shows which MAT resistance values correspond to which temperature.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 27, 2000 | 09:50 AM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
engineboy, so the mat basically just adjusts the fuel to compensate for tempature changes? what if, now this is completely theoretical, extended the MAT leads into the car and hooked a potentiometer (damn i cant spell.. just a rotary pot), then could adjust air/fuel (to a certain extent) from inside my car, while driving?
Old Oct 29, 2000 | 04:19 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
I'm not a big ECM guru but I imagine it would work. (to an extent)
The MAT is just a small piece of the fuel control puzzle.
Maybe Vader or one of the other driveability guys could help you out a little more than I can......
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 30, 2000 | 09:55 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As promised, here's the chart corresponding to MAT ohm readings and temperature.
Scoob, yes, you could. It might not affect the motor that much, but you could... and keep in mind you might throw off the MAF (see my previous note).
<table BORDER=3 CELLSPACING=3 CELLPADDING=3 >
<tr><td>Temp F</td><td>Temp C</td><td>Ohms</td></tr>
<tr><td>210</td><td>100</td><td>185</td></tr>
<tr><td>160</td><td>70</td><td>450</td></tr>
<tr><td>100</td><td>38</td><td>1,600</td></tr>
<tr><td>70</td><td>20</td><td>3,400</td></tr>
<tr><td>40</td><td>4</td><td>7,500</td></tr>
<tr><td>20</td><td>-7</td><td>13,500</td></tr>
<tr><td>0</td><td>-18</td><td>25,000</td></tr>
<tr><td>-40</td><td>-40</td><td>100,700</td></tr>
</table>
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
92purpz28
Aug 11, 2015 02:30 PM
