Plumbing Turbo
Old Feb 5, 2011 | 08:09 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Plumbing Turbo
Im trying to figure out the intake side of a turbo set up for a MAF car.
Does it go:
Air filter > Turbo in > Turbo out > MAF > Throttle body
AND where in there do I put the recirculating BOV?
Old Feb 5, 2011 | 08:30 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Plumbing Turbo
With that layout you wouldn't need to "need" to recirculate the BOV, if you vented between the turbo and the MAF. In anycase you would recirculate the BOV back into the inlet pipe before the turbo.
Old Feb 5, 2011 | 08:35 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: Plumbing Turbo
What would happen if the MAF was before the turbo?
Old Feb 5, 2011 | 10:40 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Plumbing Turbo
I've heard that the mafs dont do too well when they're pressurized. my car isnt maf though so I know nothing more about them than what I've read. IF you put the maf before the turbo, you'd have to recirculate the air to between the maf and the turbo.
Old Feb 5, 2011 | 10:49 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: Plumbing Turbo
So
Airfilter > MAF > Turbo in > Turbo out > >Recirc BOV out< > Throttle body
But where else does BOV go in at?
EDIT!
I Think I figured it out.
Airfilter > MAF > >Recirc BOV out< > Turbo in > Turbo out > >Recirc BOV in< > Throttle body
That way the air is still past the MAF and it doesn't go rich.
Old Feb 6, 2011 | 12:48 PM
firstfirebird's Avatar
Re: Plumbing Turbo
You got it!
Yeah i have done a blow-through MAF, but it's a pain to tune because of the pressure and temps created after the air is compressed.
ZZ3Astro
Aug 13, 2019 12:57 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
