fageol supercharger on ebay
Old Feb 7, 2011 | 02:08 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I know ebay listings are frowned upon but these things are really hard to come by...I would buy it myself if I had the dough
I'm not 100% sure that it is for a gen 1 60/6 though because the intake doesn't look like its meant to bolt to ours, someone whos seen one before could confirm that..
http://cgi.ebay.com/ebaymotors/Faego...#ht_500wt_1182
Old Feb 7, 2011 | 04:19 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: fageol supercharger on ebay
cant really tell...id jump on that for sure...arent those things like 1000 ish dollars when you could get them new?
Old Feb 7, 2011 | 04:23 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
More like 2-3k. Now they go for about 1.
Old Feb 7, 2011 | 04:24 PM
Engine: 3.8, 3.4
I think so(if not more), assuming that it is in fact what it says it is, I would buy it in a heartbeat, but I am broke off my ***, I just moved and haven't been able to find a job yet, and even before that things were rough. But you can't beat the performance of that for the money, $400 bolt on supercharger will be less work and money than anything else that would get you to the same power levels, you might need bigger injectors but thats about it, and 3.4 injectors would probably keep up fine on a 2.8 or 3.1.
But yeah, someone should jump on it.
Old Feb 7, 2011 | 05:13 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
It doesn't say with what it all comes with. It would suck to just buy the blower. Anyway, out of my price range.
Old Feb 7, 2011 | 05:22 PM
Engine: 3.8, 3.4
What else would it come with?? Looks like its just missing a pulley, and I think by the looks of the design it is meant to be sandwiched between the MIM and the LIM, I would think the ports would match up directly, but then by the looks of it I see no reason it wouldn't work fine with the way they are setup, as long as it does bolt up the way I think it would.
That thing would probably put my car at 281 hp, and 338 ft lbs of torque assuming my engine is making what I estimate it to be, and assuming the charger would make 6 psi of boost. I would kill stock 350s with that, esp since I have a fairly light car(wish I had a manual and hardtop though...if I had known at the time....)
Old Feb 7, 2011 | 05:24 PM
Engine: 3.8, 3.4
On 2nd thought I have no idea where the injectors would go..
Old Feb 7, 2011 | 05:28 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
I believe it was for TBI
Old Feb 7, 2011 | 05:30 PM
Engine: 3.8, 3.4
After googling it that pretty much confirms it is indeed for the 2.8 and 3.1s, numerous pics of it mounted to LIMs, though it is hard to tell if it is mounted directly, upon looking at the bolt holes and considering the fuel injectors its hard to see mounting it directly working. But I'm sure it could be made to work pretty easily. After some light reading I think it came with its own LIM, and might have been meant for carbed cars? Not sure.
And yeah, I think there were some TBI versions as well from looking at pictures.
Old Feb 7, 2011 | 06:07 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Without the intake from Fageol it's pretty much worthless....
Only good for someone that has a Fageol already an wants a new supercharger to replace a worn unit.
Old Feb 7, 2011 | 06:17 PM
Pillsbry10's Avatar
could that not be made pretty "easy" lol i use that term losely
Old Feb 8, 2011 | 03:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its missing allot of parts, the intake, the carb or TBI adapter for the top, 5-6 metal brackets, 3 pullys, some hoses......
Not worth $400 as is, buy a used blower off 3.8 for $100-150 n put in new seals and you much farther along, if you gonna spend money to fab parts to adapt it.
Also it will only work on a 2.8 or 3.1
many tried it on a 3.4 and it runs out of air quick, though perfect for a bone stock 2.8 and also when you change it over to serp belt setup for the 3rd gen, belt slip can be an issue.
Old Feb 8, 2011 | 11:49 AM
Engine: 3.8, 3.4
Something I have been wondering is where one can find cog pulleys, eventually I plan to get twin m90s, and would rather not try running dual chargers on regular ol' serp belts, and yeah I guess if it needs that much stuff it isn't worth it.
Old Feb 8, 2011 | 12:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The reason they don't run cogg on the street for the most part is if you have a backfire, it won't blow up the blower, serp belt will slip.
why 614street built a popoff valve / spacer for his, also kept it cooler.
Old Feb 8, 2011 | 01:41 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I contacted the guy selling the blower, and what was in the pics was all he had.
Old Feb 9, 2011 | 02:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
For only the blower and the size limitation it has [engine wise, to small just a 3.4] I would not paymore then $200 even being never used.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
GageBrand
Oct 22, 2015 02:30 PM
okfoz
Oct 13, 2015 02:19 PM
