oil pressure after oil change??????????
Old Nov 8, 2000 | 03:29 PM
Kevin S's Avatar
Can someone explain why my oil pressure is higher now?At normal temp my oil pressure at 2000 rpm's was like 55 to 60 now after the oil change it like freaken 80.When I floor it the guage goes out of sight.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited November 08, 2000).]
Old Nov 8, 2000 | 05:26 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Every time I floor mine it goes past 80....common for these. Maybe you were down on oil before the oil change? Wouldn't a higher oil pressure indicate more oil in the system?? Wild guess, but it makes a little sense....
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Old Nov 8, 2000 | 08:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Jason E :
As long as the oil pickup is covered by oil it doesn't know wether it has 2 qts. or 10 qts. of oil in the sytem. The pressure will not change. (unless the pickup becomes uncovered)
As far as the oil pressure being higher, could be the oil you took out was really broken down causing poor viscosity.??
I can't explain it but I've seen the pressure jump after alot of oil changes on the 2.8s.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 8, 2000 | 09:07 PM
Jason E's Avatar
Like I said, it was a guess What you said makes total sense. I just happened to notice it once and began to wonder....
Old Nov 9, 2000 | 06:40 AM
Kevin S's Avatar
Thanks for the reply guys.Before,when I changed the oil,the pressure always stayed the same.The old oil was as black as the ash try in front of me now .But it wasn't that old.It had about 6000 miles on it.I had an oil leak around the drain plug(fixed it yesterday)I had to add a quart of conventional oil to my syntech oil.You think that has anything to do with it do you?
http://v6fbody.com/
[This message has been edited by Kevin S (edited November 09, 2000).]
Old Nov 9, 2000 | 11:00 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Shouldn't, they are compatable.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
