ATTN: all with a flowmaster....kevin s, this means you
Old Nov 9, 2000 | 10:14 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
ok, a guy at my work just bought an '88 2.8 RS 5 speed and he has a 2 chamber flowmaster on it and it sounds BADA$$!! i have to get one. my question is...is the INLET pipe 2.25" or 2.50" ???? also, Kevin S where did you get your muffler and what series is it???
Dan
100% stock 1990 RS 3.1L
and VERY slow
Old Nov 10, 2000 | 12:22 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Ask the guy at work!!
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited November 09, 2000).]
Old Nov 10, 2000 | 12:36 AM
Engine: LH0 3.1L
he doesn't know....he didn't put the muffler on. the previous owner did.
Dan
and VERY slow
Old Nov 10, 2000 | 01:36 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
inlet on the flomaster is 3"...intermediate pipe (stock) is 2 1/4 o.d.
88 Firebird 2.8
MODS (either coming or on):
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A
Currently Working On:
t5 swap
Next to buy:
Slp dual cold air intake!
Old Nov 10, 2000 | 02:02 AM
88-RSport's Avatar
I think if it's a two chamber it's like mine. It's probably a 40 series. It doesn't sound like an 8 but it gives it a bad a$$ throaty sound. If it looks sorta like the stock muffler and comes out with dual outlets then it's definately an 80 series.
Old Nov 10, 2000 | 02:19 AM
Engine: LH0 3.1L
my co-workers flowmaster is shorter than my stock muffler so i assumed his was a 2 chamber. so his IS a 40 series. thanks 88 RSport.
Old Nov 10, 2000 | 03:07 AM
Administrator
Does it have dual pipes or what?? If it has dual it is probably the 80, if its not, its probably the 40.
Looking For:
87 IROC-Z 350 TPI
Old Nov 10, 2000 | 04:27 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
i have the flowmaster 80 series... The pipe is 2.5 inches but it comes with a peice that will make it so a 2.25 inch exahust pipe will fit you can even make a 2 inch exhause fit to a 3 inch its all about bending the pipe bigger.. but at high rpms whe you let off it sounds a tad *****
Old Nov 10, 2000 | 10:32 AM
Engine: LH0 3.1L
his is dual outlet but the muffler is definitly shorter than stock so i think it's a 2 chamber...not a 3 chamber. summit sells a 40 series DUAL outlet, 2 or 3 chamber.
Old Nov 10, 2000 | 10:35 AM
Kevin S's Avatar
I'm not to sure of the pipe size.
Believe it or not I got mine from the local NAPA store,it's the 80 series.But I think I'm in need of a new one.Last year when my cat clogged up on me several pieces had broke off inside and I think some of it has found it's way into the muffler.I have alot of hissing coming for the muff and one side doesn't have as much pressure coming out.
http://www.camaroforum.com/
http://v6fbody.com/
http://nethirdgen.org/
http://clubs.yahoo.com/clubs/tristatecamaro
[This message has been edited by Kevin S (edited November 10, 2000).]
Old Nov 10, 2000 | 11:36 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I ordered mine from Summit they carry two for Camaro/Firebird one is a 2.5" offset inlet/dual 2.5" outlets ($72.95) the other is 3" offset inlet/dual 2.5" outlets ($79.50)
I had the 3" inlet dual 2.5" outlets.
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Nov 10, 2000 | 12:43 PM
hmm..my muffler is all different from u guys... mines a 3 1/2 in in 3" out on the muffler...its a 2 chamber....
88 Firebird 2.8
t5 swap
Next to buy:
morrow
Jan 13, 2024 12:29 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Damon
Sep 26, 2015 04:29 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
