Need info on an engine.
Old Nov 15, 2000 | 04:51 PM
Garmer's Avatar
What are all the years & models that the GM 3.8L turbo was made. Right now i really would like another car or just the engine, as another play toy. Also is there anyway that I could fit this engine in my car?
91 RS Camaro
3.1L
Cat Back System, K&N filter,modified air box, Fastchip Stage 2, 160 thermo, Rapidfires and Bosch Wires, soon to come: Homemade Ram Air,and maybe power pulleys, 5 Air Horns
Old Nov 15, 2000 | 05:36 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
all depends on your luck.. i know of a few sitting in nearby yards, some places they're just really rare.. i believe the only ones that would fit in our cars would be out of a mid to late 80's regal t type or grand national.. or even a turbo TA, but if i find you heist one from a TTA and leave the TTA sit in the yard i would have to hurt you. :P
Old Nov 15, 2000 | 06:08 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I saw a TTA for sale 22k on ebay if u got that much chek it out
Old Nov 15, 2000 | 07:40 PM
Garmer's Avatar
So can you guys give me the years the engines were put in? Also what were the hp, torque, 0-60, 1/4, etc. on the engine!
91 RS Camaro
3.1L
Old Nov 15, 2000 | 09:57 PM
Garmer's Avatar
Does anybody know?
Old Nov 15, 2000 | 11:04 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Garmer,
If you want to know the Fbody specs for that motor, here goes....
1) Only offered on '89 20th anniversary TTAs
2) Way underrated at 250hp and 350 ft/lbs of torque
3) 0-60 in 5.2 sec, 1/4 mile in under 14 sec bone stock.
If you want the full road test stats, my site (www.geocities.com/jee89) has all the stats on the TTA
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Old Nov 15, 2000 | 11:09 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
yea i looked for a 3.8 tta motor but couldnt find one, only stuff from gn's and regals..
Old Nov 16, 2000 | 01:40 AM
Tas's Avatar
Tas
you can run a GN in an f-body with out air conditon or if you want air condion you need later model FWD3.8 heads. there is plenty of info on this just do some research. if the info has been erased on this board since the downtime check out www.3rdgen.org
Old Nov 16, 2000 | 12:17 PM
Jason E's Avatar
If I remeber correctly, Pontiac went with 3.3 heads, not 3.8s. I'll check my Hot Rod article on the car, but I believe they had to use the 3.3 heads because they were smaller overall.
Old Nov 16, 2000 | 04:03 PM
Garmer's Avatar
Jason, I really meant more about GN & Regals. The main reason is, I think that they were total sleepiers. I saw somewhere it said that a STCK 3.8 Turbo from an 86 GN, did the 0-60 faster than Corvette, Rustang, Ferriri, European cars, etc.! Could that really be true, cause that would be one bad *** V6!
91 RS Camaro
3.1L
Old Nov 16, 2000 | 04:25 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
they are.. my buddy has a gn, several small modifications, runs flat 10's on drag radials...
Old Nov 16, 2000 | 04:29 PM
Garmer's Avatar
Well looks like I found the next vehicle I get! What are the gas milege for them and how much PSI does the turbo run?
Old Nov 16, 2000 | 05:43 PM
Jason E's Avatar
Garmer,
You shoulda told me you were after GN stats
Yes, in '86 and '87 the GN was the fastest car made from 0-60, at 6 sec flat. At this point, Corvette L98s were around 6.5 sec.
The engine was rated between 230 and 240hp...I'd have to check on the exact #.
So yeah, they were the ultimate sleeper...they weren't as dominant in the 1/4 though because they have the aerodynamics of a brick A Corvette, I believe, would run a better 1/4. I could very well be wrong though!
Old Nov 16, 2000 | 07:45 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The Turbo 3.8s were available from 84-87 in Grand Nationals and T-Types. The 1984 was rated at 200 HP, 1986 - 235HP, 1987 - 245HP and the GNX 275 HP, IIRC. All grossly underrated.
I was a big follwer of the GNs and T-Types in the mid 80s and almost bought a 1987 GN in 1990. But, I was not impressed with the looks of the dash. I thought it belonged in a taxi. And then I saw the 1991 GTA in the showroom, drove it, thought it felt torquier than the GN, preferred the dash (the part I see when I drive) and wrote a cheque and drove it away.
No regrets. I still prefer the looks of my GTA (inside and out). Oh yeah, I've come across a couple of stock GNs...and I beat them.
Old Nov 16, 2000 | 11:48 PM
Car: Death Mobile
Engine: 666 c.i.
I should add, the real beauty of a Buick Turbo is the EASE of modifying it to generate big HP. Adjust the waste gate, develop more boost and good-bye competition.
That is the part I regret about NOT buying the Grand National instead of my GTA.
Old Nov 17, 2000 | 01:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Jason, they used 3.3 heads? I thought Hot Rod said they needed special heads made. Of course that was a while ago that I read that!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 17, 2000 | 08:56 PM
turbo497's Avatar
heads are from fwd unit to clear hood line. Other parts u need will be trans brace and m200 transmission your best bet is to just by a Grand national I had two of them new in 1987 they are fast!(sold one in 1993 and one is in storage since new 4700 miles) Was looking to get a third one when i found tta for sale... sounds just like GN, shifts like GN hauls a** like GN but handles better in Transam body. livin large lovin life
Old Nov 17, 2000 | 09:25 PM
Vortex_89rs's Avatar
The guy down the street from me has a GN, and not to mention a nice juiced El Cammy. That GN is fast, sometimes he will speed down the street after a night at the track with his friend (who has a Ford Fairmont or something like that). Man, I tell you what, that GN hauls some major a$$, and I love that high pitched wail of that V6. It is so awesome. If he didn't park it in his garage, I would go grab that engine in the night................
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
1969 Camaro SC
350 HO from a Vette
Turbo 350 tranny
In the process of being restored
David Frans
Oct 31, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
