2.8 to 3.8 can it be done
Old Feb 16, 2011 | 12:08 PM
JJs84Berlinetta's Avatar
I'v got an 84 Berlinetta that he 2.8 has some issues so if I am going to have to pull it anyway i want to go ahead and drop a 3.8 or would 3.4 be easier and cheaper? I want something that i can do some mods with like a turbo or superchargers. Found a lot of 3.4's and some 3.8's? Does year mold make a big diffrence? I want to keep it carburated but im willing to change manifolds out if that is al lit takes? Thanks for any help.
Old Feb 16, 2011 | 12:21 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 2.8 to 3.8 can it be done
3.4 will definitely be easier an likely cheaper, since it's shares many of the same parts an mounting with the 2.8L It basically becomes a re move an replace deal.
The 3.8 is much more work and most people that have one it, in the end, say it's not worth it. There are a few threads on the subject.
Any engine can have turbos or modifications added to them.
Old Feb 16, 2011 | 01:07 PM
Ok, i'v secided to go 3.4 but the only ones i can find are FI would like to keep carburated (but can you turbo a Carb). Would i be able to tur na FI 3.4 to Carb 3.4 or visa versa.
Old Feb 16, 2011 | 01:14 PM
This is where you need to use the search engine....
The 3.4 swap has been done in a lot of ways.
You can turbocharge a carburated engine, but it is MUCH easier to turbocharge an EFI engine.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
