What makes this car sometimes "Smoke on startup" hot or cold?
A "Greyish" smoke that smells like acrid hot exhaust, NOT Coolant. (Uts not white, its greyish. Sometimes "Puffy")
Sometimes i start it up and there is a literal "Puff" that floats away like a balloon, looks grey
ONCE it didnt smoke AT ALL, let the car sit about 12 hours or so, started it up.. smoked in the morning. Tends to do this.
Do i have a wonky sensor? Is it DUMPING fuel (means my fuel filter is ok?)
IS IT THE CARB can it do that!!?!?!????? (They say i have an "Automatic Choke and Carb but does it still get maligned?)
Im gonna cap off the emissions stuff since it sputters like i have no gas w that tape failing, but the next issue is "WTH is that little bit of SMOKE!"
Thanks 84 Camaro 2.8L V6
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: What makes this car sometimes "Smoke on startup" hot or cold?
Its usually leaking valve stem seals that cause that.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
db057
Aug 11, 2015 10:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Usually if its not too bad I'd live with it, until you have to go into the motor for something else...
