Any other mods?!?!?
Old Nov 30, 2000 | 08:03 PM
CamaroAggie's Avatar
Any other mods?!?!?
2.8L V6 MFI, rebuilt to EXACT specs(used plasti-gauge, the whole deal, wanted it perfect), bored .20 over, milled heads, new injectors, crane cam & lifters, remanufactured crank, forged pistons, accel super coil, accel plugs, accel 8mm wires, new distributor, Hypertech chip, 160 deg thermostat, K&N Filters, cold air, hi-flo cat, flomaster muffler, dual 2 1/4" pipes, centerforce clutch, Hurst shifter, took off the smog pump, AC belt removed(left the compressor on because one of these days i'll fix it); Anything else I can do? Anyone ever find headers for this car? I want to turbo it but can't find packages for less than $5,000; Just trying to find the next project for me :-) if you want pictures http://www.geocities.com/dwnshft4no1/ then go to CAMARO THANKS!
Old Nov 30, 2000 | 08:18 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
That is the nicest Sport Coupe I have seen in a LONG time...great color combo, and the engine is exactly how I would have done it, right down to the Hypertech chip!
Just wanted to let ya know, that car is awesome! Congrats on not throwing a small block in it, by the way
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires,coil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
JasonEE98 on AOL IM
"I make sure to feed my car only the best rice to keep it happy!"
Old Nov 30, 2000 | 08:49 PM
RenoLB8's Avatar
Definately a nice looking ride...for a camaro.
Did you do some higher ratio roller rockers while you were in there? Consider some 1.6:1's if you haven't.
3.1 Firebird made his own headers by ordering a set of Pacesetter 3.4 headers which bolt right on, and bending to fit the older chassis.
Next major mod? Boldly go where only one claims to have gone before: Supercharge. I'll be getting one at the end of the summer, but if someone else wants to be the prototype, have fun!
-Reno
Old Nov 30, 2000 | 08:53 PM
Thanks a lot guys! How much is a blower for the 2.8 and who makes it? I'm looking for options on what else I can do, but can't spend a huge amount. I would also like to try those headers and 1.6 roller rockers out as well. I'm also thinking that I could get more performance if I did all of these with a custom burned chip, but i'm going to wait until i figure out if i'm blowing or turbo'ing the car. Not sure how much horse I'm pushing yet either, some people say as low as 160, but stock i'm around 135, 25 horse just doesn't sound right for everything I've done. Thanks again! If anyone wants to e-mail me directly it's biggles8485@hotmail.com ADIOS!
Old Nov 30, 2000 | 09:25 PM
Jason E's Avatar
Hehe...no one makes a blower for a 2.8!!! If you want one, you're gonna have to come up with your own idea. Reno plans to take a small block designed blower and custom fab it...thats about the only way.
Old Nov 30, 2000 | 09:33 PM
RenoLB8's Avatar
Plan? Scoff at me now...but know that I WILL!!!!!! HAHA!
Old Nov 30, 2000 | 09:35 PM
Jason E's Avatar
LOL LOL
Dude, no insults meant!! Hell, you do it and you're my hero!!
Old Dec 1, 2000 | 12:06 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
posi,1.6 rockers, angle valve job on heads, 3.4 headers modified as listed b4, msd 6a or 6al, aluminum driveshaft, 4 wheel discs, prolly some other stuff i can think of
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS
Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
1982 z28..
350 4bbl black leather inside and black outside...no mods yet except for maybe the exhaust from my firebird
[This message has been edited by Graeme'sFirebird (edited November 30, 2000).]
Old Dec 1, 2000 | 01:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nice ride, Kyle! I think you should hunt down a 3.42 axle from the junkyards; if you find one with rear drums, it'll just bolt right in. You could even re-use your existing drum brakes; just switch them onto the junkyard axle.
I liked that spot where you listed the compression numbers! Mine are pretty close to that (208,000 miles later).
Those wheels are bad-*** ! Are those the American Racing AR-23's? I have the AR-46's, which are the same thing as the 23's, but in chrome steel. Hopefully I can make that change to the lighter aluminum ones next spring.
You might also want to try an adjustable fuel pressure regulator. It's been said that the v8 TPI units will work on the MPFI v6. I believe the cheaper AFPR's re-use the stock diaphragm; if you go that route you might want to try to hunt up a new one from a parts store.
Do the brass terminals on the end of your Accel plugs ever unscrew? Mine used to .. man what a pain. No matter how tight I'd screw them back on, they'd always work loose, and cause a misfire. I went back to Pep Boys, checked another box of plugs, and they had the same loose terminals.
Did you rebuild the motor yourself? It sounds like it... if so, dude, I'm going to have some major questions for you in the spring!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 1, 2000 | 01:47 PM
Yeah, I have actually noticed the little tips at the end working loose! Pisses me off, I'm thinking about switching to NGK's though. You were right about the rims as well, and I got them for sale from Pep Boys for $45 a piece. They're only 14's though. Don't have the money to bump up to a bigger/wheel tire yet. We did rebuild the motor but the car is an '84, the engine is an '85. The '84 carburated 2.8 sucked. The carb was a pain in the *** to work on, and we couldn't fuel inject it because the fuel pump was cast onto the side of the motor. We found a guy who sold us the '85 motor, radiator, and computer for $250.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
