Will these headers fit my 3.1?? exhaust questions to
Old Mar 1, 2011 | 02:49 PM
Blue1990camaro's Avatar
they say for a 2.8? will they also fit my 3.1? they shuld right?
http://www.summitracing.com/parts/PSM-70-1206/
ALSO iv been reading the stickies, now for exhaust i had n idea i just want more opinions
grabing those headers and y pipe, runing a magnaflow 2.5" highflow cat, 2.5" pipes out into a flowmaster super 44 behind the rear with the dual 2.5" tips, good or bad idea? (i already have the muffler and pipes from it with tips of fmy old iroc and the cat all brand new,)
Old Mar 1, 2011 | 05:40 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Will these headers fit my 3.1?? exhaust questions to
The heads are the same for the 2.8, 3.1 and 3.4. Yes, they should fit. There may be issues with smog fittings etc, but they will bolt to the head and fit the engine bay. I coated my OEM manifolds to keep the heat down until I get headers, but I went with a Dynamax exhaust from Summit. Sounds awsome!
Old Mar 1, 2011 | 05:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Bottom line, as has been said any number of times in the past month alone, is that yes, the headers will bolt on. You will need to remove the AIR pump and system as the headers only have the provision for the EGR valve and no fitting for the AIR check valve and parts on the passenger's side.
Old Mar 1, 2011 | 06:40 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Any reason why an AIR fitting can't be fitted into one of the header tubes? Drill a hole and weld in the required threaded fitting?? Is there room for the pump etc.?
Old Mar 1, 2011 | 08:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I would doubt there is room for the AIR pump since the #1 header tube is right where the pump and parts would sit, which is why every header kit says that the AIR parts have to be removed to install the headers.
Old Mar 2, 2011 | 03:02 PM
not sure if i can buy the headers yet, fund may not permit me to, but as far as this how yall think itl sound? 2.5" pipes, figh flow mag cat, flowmaster 80 series dual outlet (mounts sideways under the back of teh car) dual 2.5" tips?
Old Mar 2, 2011 | 03:23 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Had an 80 series... Sounded like crap even when the engine DID run right... I got so sick of the drone it produced at 70 going down the highway for hours that I couldn't wait to rip it off (other than the fact that the guy who installed it couldn't even be bothered to make sure the tail pipes were straight and cut off the cat converter AND flange to weld the whole deal together... 2.5" in and out on a 2 1/4" pipe... ). Took me 5 hours to remove it due to the fact that I only had a hacksaw at the time.
Old Mar 2, 2011 | 03:26 PM
the only gm v6 ive EVER heard dound good is my 2.8 MPFI Z24, buts its straight 2.5" off the manifold into a chery bomb glass pack and spits into duals, absolutly NO RASP very good rumble at idle, its not as deep as a v8 but NO WHINE its shocking, i wana good sound but i dont want it obnoxiously loud, my z24 u can hear BLOCKS away its so friggin loud
Old Mar 2, 2011 | 04:54 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
My setup has pacesetter headers and Y-pipe, with a dynomax catback and magnaflow cat, sounds great. If I can ahold of my exhaust clip I'll link it.
Old Mar 2, 2011 | 05:02 PM
i cant c youtube vids cuz i use a comp at my college and tehy lock teh sites,,, stupid i know right, anyway its about price right now, they r $291 shiped from summit, i only have abotu 600 to spend on exhaust as i need to fix alota other crap and i only hav $1000 to spend
Old Mar 2, 2011 | 05:15 PM
Engine: 3.8, 3.4
$600 is about what you will spend, assuming dynomax still has the rebate on the catback.
Also when you get the headers, you have to strip the paint and repaint them, that paint will flake off the moment it sees exhaust temp, and painting over it won't work either...
Old Mar 4, 2011 | 06:01 PM
well i said forget headers for now, since i found out i need motor mounts and freeze plugs, so wat i did was use the stock but new looking down pipe which is 2.5", ran a 2.5" magnaflow high flow cat, 2.5" pipes with a 3" flowmaster muffler (dont know wat series it was in my basement) that has 3in chrome tips, sounds ok, no rasp at all, its just quiet, ya know what it sounds lik, sounds lik the 4.6 v8 mustangs with quiet flowmaster exhaust if taht makes sence, not v6 sounding at all, cept at very very high rpm u can here it a little, low rpms its freakin great, just queit, but its a blowmaster, prolly not best for performance but with the new work teh car needs i had to save a little money, i got pics ill shoot em up monday probaly, looks and sounds good now
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wvcamaro
Sep 4, 2015 08:38 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
