Damn Temp Switch
Old Dec 22, 2000 | 12:21 AM
Ovrclck350's Avatar
Damn Temp Switch
Ok, so I did my tuneup, and maybe I broke a vacuum line or somethin, you tell me. Now I got in my car tonight, turned the heater on, and tried movin the temp **** to the red dark side for hot, but it was hard as hell to move, and wouldnt' move. Any suggestions?
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Dec 22, 2000 | 07:08 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Hmm.. On mine the air dam that the switch operates is entirely mechanical.. It could be stuck open, but something like this should have had a noticable onset prior to it going dead.. Only way to really check is open the airflow box to gain access to the air dam.. and I warn you in advance, it's a b*tch to get back on there correctly..
'86 Camaro SC, black /w silver stripes
MSD Coil, Accel 8mm wires, splitfire plugs.. need a job to get this list longer
Old Dec 22, 2000 | 09:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
TS, same on mine... but then again, we both have '86 cars. I don't know if later models got a vaccum line for the heater door; I wouldn't -think- so... I know 87-up got that stupid vacuum-operated heater diverter valve- but that controls coolant into the heater core; not the climate door.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 22, 2000 | 10:57 PM
Bandit76's Avatar
Ovrclck, this may sound dumb, but once I had the same problem with my A/C after messing with the radio. One of the wires in the back of it got in the way of the A/C control box somehow. However, none of the ***** worked well, not just the temp ****.
I don't know if this will help you or not.
Old Dec 23, 2000 | 12:21 AM
Ovrclck350's Avatar
Air comes out, and the thing will switch to heater and start blowing at the feet. The problem is with the lever below the one that controls AC, Defrost, Heater, Etc. It's the one that on the left has blue for cold, and red for hot on the right. It will move if I REALLY force it, but the temp doesnt' change. Sorry I didn't give all that info earlier, but what do ya think could be wrong? I haven't changed the vacuum lines yet. I had to work 11 hours today.
92 Bird 3.1L Auto
Kills:
AIM name OVRCLCK350
Old Dec 23, 2000 | 12:30 AM
Ovrclck350's Avatar
While I'm at it, does ANYONE have a vacuum diagram for a 92?
Old Dec 23, 2000 | 05:07 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I'm telling ya man, it's mechanical, not vacuum =P
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers.. still unemployed but the list is growing.. *shrug*
[This message has been edited by TechSmurf (edited December 23, 2000).]
Old Dec 23, 2000 | 06:35 PM
Ovrclck350's Avatar
I still need the diagram if anyone has it.
Are you sure it's mechanical, I mean, it's just funny i moved it back and forth before I popped my hood to do my tuneup, and I ONLY messed w/ the stuff under the hood, and it wouldn't move afterwards. I'm not doubting you, just trying to make sure.
92 Bird 3.1L Auto
Kills:
AIM name OVRCLCK350
Old Dec 23, 2000 | 08:20 PM
25thRS's Avatar
I don't believe the heater door is vacuum activated, but based on your description of the problem, it shouldn't matter.
The key point is the amount of effort you have to expend to move the lever -- clear tip off that something's binding somewhere.
I'd start by pulling the trim panel and yanking out the heater control panel. It may be completely coincidental that this prob started right after a tune up. My guess is something slipped or dropped and is causing the cable to bind up.
'92 Camaro
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Sep 11, 2015 04:04 PM
Randomtask2
Sep 10, 2015 08:37 AM
85Special
Sep 3, 2015 04:21 PM
