Vacuum Hose Size
Old Mar 3, 2011 | 04:29 PM
jjones88's Avatar
Car: 1988 Camaro
Engine: 2.8L
Vacuum Hose Size
Does anyone have the sizes for the hosing in the 2.8?
Old Mar 3, 2011 | 05:39 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Vacuum Hose Size
Really the only way to do vac hoses is to go to an advanced auto or autozone, and run back and forth a lot till you figure out all the pieces you need..or take all the pieces off, take them in, and cobble together something that works.
Old Mar 4, 2011 | 07:43 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Project 3.4 is right on. The only sure way to get the sizes right is to have a good selection of sizes right there with you. Unless you have access to your own vacumm hose selection, you want to be at a store for this task. Also, the nylon tees like to break as you pull hoses apart. The auto parts store will have these as you need them. plus this way you only buy what you use versus buying a bulk of hose and using 1/4 of it. Note: unless you are familiar with your engine's vacumm hose routing and emissions system, remove and replace only one hose at a time.
Old Mar 4, 2011 | 08:42 AM
jjones88's Avatar
Car: 1988 Camaro
Engine: 2.8L
Thanks for the responses.I was hoping I could do what I did with my 300z and buy 25 feet of .25 inch silicon and call it a day, but off to auto zone it is
Old May 31, 2014 | 07:03 AM
boeingcorp's Avatar
going to change one of mine on my 92 RS. one is totally rotted, must be the one that works the climate control, sometimes I hear hissing sounds, and climate control does not change over A/C, HEAT, VENT ... etc... These hoses turn your fingers black, and oily, very messy. Before I go to Autozone, does anyone know what the hose size is? Is it standard? Its pretty long, runs from a t valve, down drivers side fender, to the vacuum pump, any info. greatly appreciated, THX...
Old May 31, 2014 | 11:11 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Before I did away with all my vacuum accesories, I used to get the thermoid windshield washer/vacuum hose from advance auto, I also picked up the vacuum hose adaptor kit to have lots of spares on hand.
Currently the only vacuum accessory I have left is the brake booster. But I dont have emissions where I am. Safe bet your hoses are shot, but another thing to look at is where the hoses connect to the back of the HVAC panel. I had a hissing coming from there once and all you really have to do is make sure the hoses are seated firmly.
Attached Thumbnails Vacuum Hose Size-forumrunner_20140531_121047.png   Vacuum Hose Size-forumrunner_20140531_121106.png
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
m00n420
Sep 11, 2015 02:39 PM
timonator
Sep 10, 2015 07:55 PM
