Help finding an engine
Old Mar 8, 2011 | 05:17 PM
RoosterC's Avatar
Car: 1988 Maui Blue Camaro
Engine: Pea Shooter
I've been scouring the forums, paper, and craigslist to no avail in my search for a 3.4L FWD V6. Wanted to know if anyone knows of a site or source I haven't tapped into. (not sure if Ebay is reliable)
Old Mar 8, 2011 | 05:40 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Help finding an engine
Have you tried your local junkyard?
Old Mar 8, 2011 | 05:46 PM
ex-x-fire's Avatar
Today the newer 3.4s are like the 350s in the 70s, GM puts them in everything. Most good JYs can get an engine from another JY if they do a search on their network.
Sometimes I'll go on Craigslist & look outside my area for parts, so I might have to drive a couple hours to get what I want.
Old Mar 8, 2011 | 06:18 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Wouldn't you need a RWD if you have a camaro?
And where do you live?
Old Mar 9, 2011 | 03:09 PM
RoosterC's Avatar
Engine: Pea Shooter
Didnt think the junkyard would have any running engines, pretty good idea though and thanks for the info ex-fire
I want the FWD because it's a slightly better engine, this is called a hybrid swap. You can search the forums for KED85's 3.4L engine swap and all the info you'd need to do it.
I live in WA
Old Mar 9, 2011 | 03:23 PM
DaKrames92's Avatar
Car: 1992 Firebird
Engine: 3.1l
have you tried car-part.com? that site usually helps me find the parts i need, or at least gets me the relative junkyard that might have parts. just search any year car that had the FWD motor
Old Mar 9, 2011 | 03:52 PM
AmorgetRS's Avatar
If you are in WA, Pick N Pull (formerly Pull-A-Part) almost always has 3400s.
You don't need or even want the entire engine, though, you just need the heads and intake.
Old Mar 9, 2011 | 05:52 PM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
I live in WA
I didn't know you were doing a hybrid. Good luck in your search.
Old Mar 10, 2011 | 04:37 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I live in WA
You are wrong about pretty much all of that, unless you have a rwd 60/6 that you plan to put the 3400 top end onto.
Putting a fwd engine in your car isn't a hybrid swap...its just an engine swap, the swap articles on this board for the 3.4 are for the rwd version, not the fwd version.
Old Mar 10, 2011 | 09:14 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Old Mar 11, 2011 | 03:37 PM
RoosterC's Avatar
Engine: Pea Shooter
I guess I had the idea of the hybrid swap being that you take out the FWD and convert it to RWD wrong, oh well.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
