Rear end with disc brakes ...
Old Jan 6, 2001 | 09:19 PM
Bandit76's Avatar
My rear end is starting to go, so it's time to hit the junkyard and get a replacement.
I know it's a longshot, but I'd really like to find a rear with disc brakes and something in the range of 3.23 to 3.42. My car has a 3.23 right now, which I'd like to upgrade, but I'll trade for rear disc.
Any suggestions on what I might pull this off of?
Old Jan 6, 2001 | 09:33 PM
Monkie's Avatar
an IROC-Z
or you could get a 4th gen rear end but it will make the wheels stick out. I think 2". Do you guys think that would look bad? Like a thug's car...
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
Old Jan 6, 2001 | 11:33 PM
Kyle F's Avatar
Yea it will look bad in my opinion(some people like it though). If you do get a 4th gen remember some are 2.73's so ceck it first.
To fix the wheel problem of sticking out just upgrade to a 4th gen wheel or one made for the offset of the 4th gen. Then buy the spacers for the Front. I plan on doing this to my T/A because I don't want to giver up my Disc for a lower gear because I like my car to perform in all aspects. So this is the easy way to get a low gear and keep disc. 'Cause you know you can't find anything cheap for a 9-bolt
Old Jan 7, 2001 | 12:19 PM
Monkie's Avatar
So the wheels will only stick out if you have 3rd gen wheels? So if I get those Vette wheels they wouldnt stick out?
Old Jan 7, 2001 | 10:33 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
probably not, the offset for a corvette is huge. There's a place by my house that's selling 4 vette wheels with tires for 500 i think. They're the C4's though, least i think they're C4 wheels and not C5's. Looked good, but the offset is what turned me away, but how i'd love to look under my car and see 10 inches of rubber per wheelwell.
Old Jan 8, 2001 | 08:47 AM
Kyle F's Avatar
That is correct Monkie, Corvette wheels have the offset to keep them from sticking out, but you might have to modify your wheel wells
Old Jan 8, 2001 | 11:38 AM
Monkie's Avatar
Well they sell them as "Corvette, Camaro, and Firebird" wheels. But they are talking about the fourth gen Fbodies. I hope they fit fine. Im sure they will. Oh and to the guy that posted this...Sorry man I took this way off topic.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
Old Jan 8, 2001 | 11:43 AM
Bandit76's Avatar
Monkie, topics are like converstaions, they go from one subject to another and back in the course of their duration.
I don't think 4th gen wheels fit our cars, I heard about a guy who tried it and it wouldn't fit, sorry but I forget why.
As for the IROC Z rear, my friend has an 89 and it does not have rear disc.
Old Jan 8, 2001 | 12:13 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
bandit, just call around different boneyards.. my buddy's 89 iroc has rear disc's but my 87 iroc doesnt.. it varies from car to car, i also believe most WS6's had rear discs, but ive never seen one in a yard..
Old Jan 8, 2001 | 03:36 PM
Monkie's Avatar
Yea 4th gen wheels will fit our car. You just need to get an adapter. But since you need a rear end anyways why not just go ahead and get the 4th gen rear?
Old Jan 8, 2001 | 09:02 PM
Kyle F's Avatar
Yes my Brother has a set of 98 Z28 Rims on his 89 RS 305TBI. Worked fine with Spacers.
Old Jan 10, 2001 | 09:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Bandit, you didn't mention what year of car you had.
If you can, hunt down an 89-up rear axle. 82-88 rear discs had a design problem- it can be fixed with the service bulletin parts, but those parts run over $200!
Also, the 89-up rear axle will re-use your J50 (meaning disk/drum brake setup) master cylinder! You would still need to grab the proportioning valve from the donor car, though. They're available "new" from GM for $80 or so. There's one more thing you have to check for- where the "front-to-rear steel brake line" enters the proportioning valve- on both YOUR car and the DONOR car. If they don't match, you'll either have to bend your car's brake line to meet the "new" prop valve, or (what I did) get the front-to-rear brake line from the donor car.
Search this topic on the Suspension/Chassis board, and the Transmission/Driveline board. I've posted many times about the swap.
Oh by the way I have a 1984 Trans Am's 3.73/posi/disc rear axle in my car. 1982-1985 were the only years you could find 3.73's. Make sure you check the ratio of the donor car's axle! I stumbled across an '88 formula with rear discs- but it had a 2.73:1 rear gear ratio. (My car had a 3.42 originally.)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
