Brake Question
Old Jan 9, 2001 | 10:33 PM
Ovrclck350's Avatar
Brake Question
Ok, everyone knows that annoying scraping sound when your disc pads are wearin out. How long do i have before I ABSOLUTELY NEED new ones. For now I bent the little pin out of the way to get rid of that damn noise, plus I don't like it constantly touching my rotor. I'm kinda low on cash and need to know.
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Jan 9, 2001 | 10:52 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
dude, the last time my "wear sensor" started scraping i was like "what the friek...i just replaced those pads?". i looked at them and i still had about 35% left. anyways, i'm saying that the sensor doesn't mean you NEED brakes IMMEDIATLY. my suggestion would be to LOOK at the pads and see how much you have left. if you still have alot, just bend the sensor back a little so it scrapes when you DO need new pads.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Jan 10, 2001 | 09:03 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My front pads wear at a slight angle, and wear differently between the outer & inner shoe. Make sure to check all edges of both pads- a pad that looks thick in one spot might be thin as hell in another!
(I've also bent that scraper out the way after checking my pads)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 10, 2001 | 03:18 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
it's a safty thing to change the pads when they start scratching, if you have to make an emergency brake, (120 to stop) and your pad is too thin, it could get blown away and than it's not only 50 bucks you have to spend on. tho it's no saving to bent the sensor
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel
Old Jan 10, 2001 | 06:02 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
only way to know is to actually check them.. ive seen a lot of people install pads upside down with the wear "scrapper" on the bottom because its easier to put em on that way, but then you get stones that can jump up and bend it in making it scrape prematurly.. ive had bent indicators scraping on several week old pads, and ive also been down to about 2/10r of backing and it still wasnt scraping..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
