Ok Im going to a junk yard this weekend and Im wondering what I will need to get for the 145mph speedo and put it into my RS that has a 110mph speedo. Only thing is how will the tach work or will it work? Because the redline will be off. Thanks ahead for the info!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Soon to be a 3.8L turbo RS
AIM screen name - Stopsign696
Kills:
95 (****) Probe GT,94 Mustang GT,91 CRX (dont ask me why he raced me),2nd Gen Z28 (350) haha to you V8 guys!,1992 RS 305 TBI (good race),First Gen Integra, Old Escort LX
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
WEell I would think that it wont matter, all you need is the guage cluster. The Tach Might read differently because I don't know what the different redline is between the V8's and 6's. It will all read correctly though because the readins from the transmission and ignition won't change. Or atleast this is what I am thinking because I wouldn't see why anything would be different, but I was lucky enough to have a 8000rpm tach and 140mph speedo from the factory.
So all I need to get is the tach? Thanks!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
2011 Norwood Gathering
ThirdGen Firebird Rep
Jason E
close
WRONG.
The sending unit for the oil pressure will not work, nor will either the engine temp or the voltmeter (one of these works, one won't, I forgot which one....but you'll be able to tell.)
Take the 145MPH speedo out and put it in the V6 cluster....FAR easier.
Jason E
'89 Camaro RS 2.8 (Medium Gray Metallic)
Hypertech chip/K&N filters/Accel 8.8 wires, Accel Supercoil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm, Keyless Entry
IROC tailights, tinted windows
JasonEE98 on AOL IM
Jason E
JasonEE98 on AOL IM
you will also need a new cable for the speedo, cause your old one is only 110 whenever you hit 110.... with the new 140 speedo it will read 140. SO it will look cool, but you will have to guess how fast you are really going.
yeah, it's alot easier w/ the older gauges. all I had to do was swap speedos and swap my v6 gauges into 145 speedo cluster. Too bad it's not that easier w/ the 92's cluster
Why didn't GM make the temp and Oil pressure sending units the same? That is so stupid. The speedo will sork fine the cable is turned by a gear that turns a gear inside the speedo, nothing should change here. I was unaware(while working at a parts store in high school)that we should ever ask what speedo you have before selling a cable. I am thinking still that it will work, but I could be wrong. Has anyone actually done this and left their old cable in?
Kyle, hush.
Monkie, you don't have a speedometer cable. You have an electronic one (yes, I know, it's not digital- but it's still electronic.) GM got rid of cable-driven speedometers in the late-80's.
Previously, the speedo was driven by a cable coming from the tailshaft of the trans. The VSS was built into the back of the speedometer, and was spun by the speedo. The VSS then sent the electric signal to the computer.
On your design with the electronic speedo, here's what happens: The transmission spins the VSS, now located in the tranny's tailshaft. The VSS wire goes to both the speedo and computer.
If you find another 145 speedo from an 89-up car, it will go in fine. If you find a 145 speedo from, say, 1982, it won't work.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Hey Tom if I got one out of like a 89 or so IROC or Z what else will I need and will it fit right? Thanks you guys (even Kyle
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
Jason E
close
Irrelevant question for Tom...
My '89 has no speedo cable? Why does it "swauqk" when its cold out (aka under 20)?? I was told that was because of the speedo cable...
Jason E
JasonEE98 on AOL IM
Jason E
JasonEE98 on AOL IM
slowcamaro88sc, exactally what i was thinking, i dont think a older gauge cluster will bolt up the same.. ive never worked with the new redesigned ones at all but are they one peice or can you just swap the speedo by itself? in that case, just swap the speedo..
kyle, unlike ford which doesnt even make many v8's anymore, gm uses different senders for different applications, ie, 0-60psi and 0-80psi oil pressure senders, or higher temp senders, as as the application varies so will the range of data the sender must send.. (had to be a smartarse.. :P )
4.6l GT?? Oh you mean the phoney pony..
Quote:
nope, the 90-92 dash is one piece so you can't remove just one gauge.Originally posted by scoob8000:
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
dang.. thats kinda rough.. i kinda like the layout of the 90-92 gauge pods, but it seems like too much of a pain if you got a bad unit.. reminds me of a digital dash i attempted to repair on a berlineta.. tho they look schweet, their a total headache...
I just dont like how they are half a circle.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
More to come
i personally like the 90-92 gauges WAAAAAY better than the 82-89.
Dan
1990 3.1L RS
Dan
1990 3.1L RS
JasonE, you'll have to check under your car to see if there's a speedo cable coming out of the tranny's tailshaft. It comes out the driver's side, and runs along the fuel lines under the car for a while. There's always debate as to whether GM went to digital in '88, '89, or '90.
yeah.. my 87 is cable driven but the 89ta i had was the electronic speedo..
