on cloud nine
Old Jan 25, 2001 | 07:03 PM
HIX5000's Avatar
on cloud nine
Today I finally got everything to work as it should with my car. I have had this car for almost a year and a half, and it hasn't run right the whole time. If it wasn't an ignition problem it was idling too high. But today I finished putting it back together, and after a timing adjustment it idled right at 750. The car has never idled below 1500!. I took it for a spin and it ran beautifully. Words can't express how stoked I am. I would like to thank everyone who helped me with any of the numerous problems i've had.
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Jan 26, 2001 | 11:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sweet! What did it take to fix the car? Last I remembered your plugs were oily; did you rebuild the motor?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 26, 2001 | 12:20 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
congrats buddy, so what did it take to get the car running well? Just curious. Well, one job done, now it's time to go for speed huh.
Old Jan 26, 2001 | 07:42 PM
HIX5000's Avatar
I don't know a whole heck of a lot about cars. Everything I do know I have learned from you guys or by just trying to do it myself. So I told someone about my plugs and he said I needed new heads or possibly a rebuild. Hence my post on oily plugs. However when I explained my situation fully on the tech/engine board I was told that the oil was probably from leaky valve cover gaskets. What I didn't mention in my oily plugs post on this board was that the oil was on the plug wire side of the plugs. To cut it short I didn't explain my problem to you guys fully. Sorry. So I guess i'll be hanging on to the 2.8 a little longer.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
[This message has been edited by HIX5000 (edited January 26, 2001).]
Old Jan 26, 2001 | 07:58 PM
85f-bird's Avatar
Engine: 2.8L, LS1
so dude, u mean that your oil was hanging over say, the wire itself, or even the outside of the housing that connects to the spark plug, yeah, that sounds like an external leak somewhere, and most likely is coming from the valve covers, or head assembly area. Thanx for the completed info. good luck on the fix, and it should be cheaper than a new block.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
chazman
Aug 28, 2018 03:25 PM
tyeo098
Nov 30, 2015 06:27 PM
chazman
Aug 22, 2015 02:01 PM
