How much HP does a 3.4 have?
Old Jan 24, 2001 | 04:08 PM
Sweet_85_Bird's Avatar
I want to do a 2.8-3.4 swap.Can someone who is doing this or knows hook me up with all i need to change and the specs like 1/4 mile and HP and torque for the 3.4.
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Jan 24, 2001 | 04:23 PM
irocbsa's Avatar
160 I think. That is if you're talking about the ones out of the 4th gens.
bsa
Old Jan 25, 2001 | 07:43 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I have a 3.4 in my 2000 Grand Am. I know its FWD. Anyway, they rate it at 170HP, and the GTs w/ Ram Air are rated at 175.
My car is also rated 0-60 in 7.8 sec. Haven't actually timed it yet.
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
"Little girls play with ponies!"
www.geocities.com/camman86
Rock fans click the secret link on my site!
Old Jan 25, 2001 | 09:42 AM
Mike Harvey's Avatar
Yeah I have heard mixed reactions about the HP nubmers off of the stock 3.4L in the F-body. I have heard everything from 160-180 HP, so who knows. I would estimate 165 to be on a safe side. As far as torque goes, I have no idea.
This is what will be needed for the swap. The entire 3.4L. All the parts between the 3.4L & the 2.8L are interchangeable. Everything will bolt up. The only other thing that you will need from the 3.4L will be it's fuel injectors. You can't use the intake, well unless you want to reroute all those little plastic vaccum lines & not use your stock distributor. I would suggest a full rebuild & take your time & do it right & make it really pump. Forged EVERYTHING that you can find.
- Mike Harvey -
1986 Firebird S/E
Old Jan 25, 2001 | 05:34 PM
SlowCamaro88SC's Avatar
how does 200 torque sound... makes sense.
2.8 = 165
3.1 = 180
3.4 = 200
Old Jan 25, 2001 | 06:03 PM
I should clarify what I said in my last post about rerouting the vaccum lines. What I meant was if you used the 3.4L intake things would not work. The vaccum lines would have to be shaped differently or something plus you can't use your original distributor if you use the 3.4L intake. I hope that what I said before is now clarified. Later guys.
- Mike Harvey -
1986 Firebird S/E
Old Jan 26, 2001 | 06:56 AM
FBODY-ADDICT's Avatar
Front wheel drive 3.4's got the aluminum heads and should be able to get around 20 HP more than the iron headed 3.4's on fourth gen. F-Bodies. So if a stock 3.4 firebird makes 160hp, the FWD Grand Ams would make 170-175.
[This message has been edited by FBODY-ADDICT (edited January 26, 2001).]
Old Jan 26, 2001 | 07:40 PM
rwd 3.4 = 93-96
fwd (the ga motor) 3.4 = 98-01
there's a few years and alot of evolution between there.... there's gotta be more of a difference there. don't forget engine tuning and the like.. don't correct me on the years if I'm wrong, tho I prolly am..
Old Jan 27, 2001 | 12:01 AM
KED85's Avatar
I am wrapping up my 2.8-in-disguise for the smog people in LA.
I can't wait.
All I know is it's alots of small details that will bring big results!
Make it real easy,have both side by side and start recreating the 2.8, onto the 3.4 block.
You'll win big time.
Saturday, I turn my key!
DO IT
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
92projectcamaro
Aug 6, 2015 01:20 PM
87CamaroLT
Apr 23, 2001 09:32 PM
