Tranny Mount...again
Old Jan 31, 2001 | 06:48 PM
Ovrclck350's Avatar
I believe my transmission mount is broken, AGAIN. What could keep causing them to break?
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Jan 31, 2001 | 08:28 PM
25thRS's Avatar
First, I'd check the engine mounts to make sure they are tight and solid, to prevent excessive rocking. Next, check overall alignment, from the engine to the rear axle. Don't forget to check the pinion angle. If all of these look good, check out your sig. Driving hard breaks things. Unavoidable. No lecture or moral judgement. Drive as you like, but if you race a lot and push your ride all the time, accept that things are going to break.
Old Feb 1, 2001 | 02:25 AM
RenoLB8's Avatar
What would cause your mounts to break? Driving, of course! Seriously, you don't even have to be mean to it, and you'll break a tranny mount pretty quickly. I recommend Energy Suspension Polyurethane mounts. $20, Summit, delivered within a week, and never have to buy another in your life. They're very tight and a pain to put in compared to the stock ones (so set aside some extra time, I got in deep crap with my woman cause I thought it'd be a fifteen minute job like the stock one).
-Reno
Old Feb 1, 2001 | 07:26 AM
Ovrclck350's Avatar
What's different about the install on these?
Old Feb 1, 2001 | 09:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with Reno, get the ES trans mount. I went through two stock ones in three years before buying the ES poly one from Summit; now, this ES one has lasted me 4 years! Well worth the $25.
Mine went in with no problems. If your trans has shifted a bit in relation to the crossmember, then the bolts will be tight. It's not so much dependant on the mount, but on the car it goes into.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
