Oil Change with no owners manual
Old Mar 20, 2011 | 02:55 PM
Erich504Camaro's Avatar
this may seem stupid, but i need to find out what kind of oil my 2.8 v6 requires and how much i should put in it.
Old Mar 20, 2011 | 03:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Oil Change with no owners manual
10W30, 10W40, whatever - depends on your climate more than the motor.
At least 4 qts, maybe 5. Dump in 4, start car, run it for 1 minute, then shut off (this fills the filter). wait 10 minutes, read dipstick - probably need another added.
Old Mar 20, 2011 | 03:28 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
It take 4.5 quarts of either 5W-30 or 10W-30.
Old Mar 20, 2011 | 10:44 PM
RT66DAVE's Avatar
The only stupid questions are ones we don't ask. Gm specs out the oil as 5w30 from the factory. The capacity is 4 quarts using the short oil filter. however, you can use the longer AC PF52 oil fliter and that will increase the capacity to 4.5 quarts. 10w30 works well too. Capacities can be found in shop manuals such as Haynes or Chilton's, or the Factory service manual.
Old Mar 22, 2011 | 08:53 AM
thanks man, yeah i just got the car back on her feet. im soon going to strip her down and build a Outlaw drag car.
Old Mar 23, 2011 | 12:56 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
they actually take 4.5 qts even with the short filter.
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
