HT 3.4 , will it work in 88 Camaro?
Old Jan 24, 2001 | 07:52 AM
Lov2xlr8's Avatar
The Gm performance parts book says it is for 82-85 blazers, will it bolt into my 88 camaro with MPFI?
Teach your children the dangers of Rice
Old Jan 24, 2001 | 12:15 PM
FBODY-ADDICT's Avatar
Hey man Im getting ready for the 2.8-3.4 swap and as far as I know it will work, you will have to take your comp. and fi, all your accessories plus the 3.4 injectors and put them on the 3.4 block.
Old Jan 24, 2001 | 02:17 PM
Lov2xlr8's Avatar
Im not woried about that, its just tht the ad says its for an 82-85 car, but I have an 88, Im worried if all the bot holes are in the same spots and stuff. I have to upgrade injectors? cant I just get a higher fruel pressor regulator.
Old Jan 24, 2001 | 05:37 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
shouldn't have a problem, all the 2.8L bolt patterns were the same for the 2.8L-3.1L and i think the 3.4L too. They are the same block.
Old Jan 24, 2001 | 10:20 PM
pods8's Avatar
Yes my car is an 88 too.
-pods
88' Sport Coupe W/ T's
2.8->3.4 5-speed, accel coil-8.8 wires w/ bosch platinums
black and silver, grey interior, w/ 95' cloth seats, 3way power driver
Old Jan 25, 2001 | 05:06 PM
Lov2xlr8's Avatar
some body said I will have to change the manifold? is that true? he also said I will have to re route vacum lines.
Teach your children the dangers of Rice......88 RS 3.4L 2000 BMW silver. Black and grey interior.
Old Jan 26, 2001 | 11:26 AM
Yup, you take the intake and FI from your 88 and pop them on the 3.4.
Old Jan 27, 2001 | 12:08 AM
KED85's Avatar
This is a very detailed swap.
Lots of little things make it work right.
The idea is very simple, tho.
Recreate the 2.8 onto the 3.4 block.
Need to keep the 3.4 balancer & flexplate, as they are neutral balanced.
Go get a running example from the wrecking yard, you'll win better!
I got a 40K 1995 long block for $800.
I turn my key on Saturday.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 2, 2001 | 06:44 PM
KED85's Avatar
I just got my swap dialed in.
IT'S INCREDIBLE!!!!!!!!
I AM STUNNED and this is from one that owns a 1974 Corvette!
The front end LEAPS!
And I still have the old 2.8 in the trunk area. I can't wait til I remove that weight!
DO THIS SWAP!!!!!!!!!!
WORTH IT!!!!!!!!!
Chat Soon,
KED85
Karl
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
92projectcamaro
Aug 6, 2015 01:20 PM
