Car has miss
Old Feb 3, 2001 | 07:09 PM
CSUS_Dude's Avatar
Car has miss
I've got an '88 2.8 5-speed that I'm trying to get smogged. It has a small miss from idle up to about 3000 rpms. I've replaced plugs, wires, cap, rotor, and set the timing dead on at 10 degrees. I've also run fuel injector cleaner through it. No vaccuum leaks either. The car has been sitting for awhile, but I don't know what else to check. The car only has 106k miles. Any ideas?
Brandon
Old Feb 4, 2001 | 09:00 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I'm young, and not to sure when it comes to this stuff, but we had an old Celebrity that had that problem, and I remeber it had a warped valve, so we hadthe valves ground, and the warped one replaced, and reseated them. Tha brought the compression back up, as well took the miss out.
[b]My site http://www.camaro3rdgen.20m.com
Old Feb 4, 2001 | 09:09 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
When you swapped the plugs did you notice anything abnormal about one? Usually a missing cyl's plug will come out fouled, usually oil fouled. It's probably due to a low compression situation... rings, valve guides, bad valve, etc.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4
In search of new v8 engine & transmission
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
