(computer) tech question
Old Feb 8, 2001 | 02:28 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
ok guys i just took some pics of the RS. i don't have a scanner but i *should* have access to one.....my question is: is it possible to scan some pics and then save them to a zip or a floppy so i can take em back to my computer???? or should i just BUY a scanner???? any recommendations????
hmmm, i need real tech don't i.......um, what's the stock ignition timing on a 1957 bel air with a 327 cubic inch engine????
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Feb 8, 2001 | 03:16 AM
87RS402's Avatar
You can scan and save to floppy, zip, or cd. You can also e-mail then as attachments. Use .jpg for the format it has better compression and make a file about 10 times smaller than a bitmap ( .bmp )
If you buy a scanner, I tend to like the USB ones better. If you have a printer and try to use a parallel scanner with it some printers won't work ( they won't share the port ) so just add USB ports if you don't have them, it's about as hard as changing a ignition module.
Old Feb 8, 2001 | 09:49 AM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 87RS402:
so just add USB ports if you don't have them, it's about as hard as changing a ignition module.</font>
lol, I like how you simplified it into car terms. Actually tho, it's easier than that. It's about the equivalent of plugging in a new prom.
Old Feb 8, 2001 | 11:12 AM
KED85's Avatar
Stock timing runs from 4 to 10 TDC.
Usually use your ear & wrench & a hill for testing.
Listen for ping, back down slightly.
If ya get alot of ping, increase air into air cleaner, by RAMMING IT IN.
Not an open air cleaner. Open cleaners only get hot engine compartment air, not truly helpful for your mission.
Buy a scanner, to.
Can save "pic" on any "disc" format your computer already has.
My iMAC ahs USB ports, so I added.
I also only have a CD, on this computer. I added another computer (network system) & hard drive re-writeable disc for storage.
Lots of work, but, I got a great computer system, now.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 8, 2001 | 03:12 PM
Engine: LH0 3.1L
hehehe, sorry KED85, i guess you didn't see "my cousin vinny".....the 327 didn't come out till 1962 or 63 i dunno. thanks for help guys.
Dan
1990 3.1L RS
Old Feb 9, 2001 | 06:19 PM
KED85's Avatar
OH YES, I"VE SEEN "My Cousin Vinny".
I'm glad my Wife is like Marissa Tomei, she drives a 1968 Camaro! But, I won't let her touch my 1974 Corvette ever again, tho.
Now, your question never said a "Stock" 1957 Chevy with a 327.
Incidentially, 327 appeared FIRST in the 1962 MODEL YEAR, which was first introduced to the general public late summer of 1961.
I've know alot of 1957's w/327's under the hood, in my lifetime.
I remember, one specifically, smoking from the rear wheel wells, coming up the slight incline in front of my Junior High School in 1970. And it was a 4 door! It was great to grow up in the 60's & 70's!
Chat Soon,
KED85
Karl
Cleotiz
Jan 6, 2018 08:56 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
