Please help: stalling, rough idle
Old Feb 10, 2001 | 05:47 PM
matlock's Avatar
Car: 89 GTA
I adjusted my timing and now my car accelerates a lot better especially up hills. Before doing so my car had a moderately rough idle, idled at about 600, and never stalled when coasting.
Now my car idles at 500 when warm and sometimes stalles when coasting. Today I tried to raise the idle but with following the procedure in the tech article, when I d/c'd my IAC connector and tried to start my car it wouldnt last for more than half a second. After reading over the procedure many times and messing with it, I got impatient and just shut off the car, raised the idle, then unplugged the battery cable to reset the computer.
My car now idles at 750 in Drive, but now it seems to be running rougher at idle and it still stalls on me sometimes when coasting. This only happens when it has warmed up.
I did the MAF sensor test: unplugging it and seeing what happens, but the car still stalls. I'm not getting any error codes and wondering if I should get a shop to put it on a scope, or if it would be cheaper to just start replacing sensors.
Thanks.
[This message has been edited by matlock (edited February 10, 2001).]
Old Feb 10, 2001 | 07:59 PM
KED85's Avatar
I know what you've got.
How many miles? close to or over 100K?
You need a timing chain!
Do that & you'll be much happier.
Or just junk the 2.8 & throw in a 3.4 long block like I did.
It now pulls like a freight train!
Really, you need a timing chain.
How to test.
Pull of dist. cap, put socket (I beleive 17mm) & turn crank with socket.
Watch how long it takes to move distributor.
If it take about an 1" or so, you need a new chain!
Also, use 2 cans of Liquid Gumout & preminum gas. Waste the tank, then try same combo again. IF it doesn't get any better, you need some work!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 10, 2001 | 10:09 PM
matlock's Avatar
Car: 89 GTA
Its actually got about 14,000m on a rebuilt engine. Ill try and that a check on that though. Maybe they installed a used timing chain to rebuild it.
Old Feb 11, 2001 | 05:59 PM
mAjInRS's Avatar
i have the same problem but i have a 3.1 with like 165,000+ miles on it, its fine till it warms up then it will die sometimes if i coasting to a stop or if i'm sitting a light, i havent tried messin with the idle either.
91 Blue RS with ASCD SS hood w/hood pins, Flowmaster 80 series w/3 inch dual exhaust, K&N, Hypertech Power Chip, Bosch Platinum wires and plugs.(19 years old and all this bought and paid for by myself, except the car that was paid for by State Farm...long story with the minor fender benders and them not wanting to pay for repairs...mwahaha)
jklein337
Sep 19, 2018 06:23 PM
greenyone
Sep 2, 2015 03:39 PM
IROCtometal
Sep 2, 2015 02:01 PM
masonta
Sep 1, 2015 06:40 PM
JHX
Aug 29, 2015 02:30 PM
