SPARK PLUGS??
Old Feb 14, 2001 | 10:33 PM
Sincat_23's Avatar
SPARK PLUGS??
IN your guys opinion, what spark plugs do you guys find to be the best for our V6s or work best with a MSD coil? Thanks
92 Camaro 3.1 V6 (Red)
-Hypertech Chip
-Dynomax Exhaust
-Taylor Spiral Spark Plug Wires
-2.5 Harwood Lift-Off Cowl Hood
-B&M Megashifter
-B&M Shift Improver
-15x8 Crager 5-Star Chrome Rims
-JSP Apache Wing
-Yellow Weapons-R Intake Filter
-KYB Shocks & Struts
-Borla Exhaust Tips
-MSD Coil
Old Feb 14, 2001 | 10:48 PM
RenoLB8's Avatar
Most guys will swear by the AC Delco Rapidfires, but I'm a big fan of Splitfires.
Whatever you do, DO NOT GET BOSCH PLATINUM +4's. Waste os money and time.
-Reno
Old Feb 14, 2001 | 10:53 PM
Sincat_23's Avatar
Thanks Reno!! I really love this message board, I'm learning alot
-Hypertech Chip
-Dynomax Exhaust
-B&M Megashifter
-B&M Shift Improver
-JSP Apache Wing
-Borla Exhaust Tips
-MSD Coil
Old Feb 15, 2001 | 02:02 AM
Johnny Ray's Avatar
I beleive I get 'more bang for the buck' with AC Delco Rapidfires.
My suggestion is try whatever your choice may be and see if your engine likes them. If it doesn't, try your second choice.
1992 Artic White Firebird
1997 Black Firebird
Old Feb 15, 2001 | 06:20 AM
Brian K's Avatar
NGK is not bad, AC Delco makes some nice ones, I would avoid splitfire like the plauge. (Had a bad experience with them)Since i change mine every year I usualy go with stock AC Delco's or NGK's...
Old Feb 15, 2001 | 10:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh. I've used Splitfires every year (except one) since 1994, and have had no problems.
What did I use that one year? Accel U-grooves. The brass terminal that the plug wire clips onto would constantly unscrew from the plug! After a month or so I'd get a misfire... so I'd have to tighten the terminals up again. I thought maybe I got a bad set, so I checked another package- same thing. The terminals on the U-grooves in the store package were so loose I could unscrew 'em by hand! I've heard that other U-groove users have had the same problem. I'll never buy those again- they were too much of a pain in the butt.
So I wouldn't say to avoid Splitfires like the plauge!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 15, 2001 | 11:22 AM
Brian K's Avatar
I used splitfires when I was into car audio... It was the only plug to give my setup engine noise. Then they went bad...I took 2 back and got replacements after only 1 year. Stock AC delco's look pretty good after a year, drastical cleaner compared to the splitfires I was given. In my opinion it would be better to buy better wires, cap, rotor, and MSD Coil before you toss your money on expensive plugs...
Old Feb 15, 2001 | 12:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's odd; maybe you got the wrong heat range? My plugs always look clean. I posted a thing a while ago regarding heat ranges; seems that GM decided that in '88, the 2.8's should get a hotter plug. Splitfire still lists the colder plug for the '88 motors... and a colder plug would look dirty & oil-soaked. I remember quite a few people (mainly with trucks) complaining about oil-soaked plugs; I bet Splitfire had their heat range listed incorrectly.
But that's definately true; plugs are plugs, the "best" increase you get is by replacing old worn out plugs with brand new plugs. Split's are $4/ea right now, by buying a less expensive plug, you could get a new cap and rotor, or put the cash towards a good set of wires or a hotter coil.
Old Feb 15, 2001 | 06:14 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Rapidfires! I need to do a tune up now that im thinking of it and gapping further...
89 Firebird (AKA "Money")
2.8 V6 w/ t5 tranny (383 tpi t56 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
Next:
Spohn Torque Arm, Lakewood Panhard bar, BMR Fabrication Sub Frame connectors...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Feb 15, 2001 | 11:47 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
So far in my car ive used NGK, BOSH, Normal AC delcos and Rapid fires Rapidfires by far are the best
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
