troublesome intake valve/rocker
Old Mar 29, 2011 | 03:23 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Adjusting my valve lash and for some reason #5 intake valve wants to be too tight to be tight enough, all the others adjusted just fine, but #5 intake the nut is noticeably lower, and it actually made the engine not turn over, but I tightened it using the proper method which is what I don't get.....I also managed to bend the pushrod slightly when trying to turn the engine over by hand, any reason to suspect I killed the lifter or should that be fine? And ofc wth is this valve being so stubborn, I can't see any logical reason for it...other than a toasted cam lobe, but if that were the case I don't think it would encounter resistance like that when over tightened. Need some advice...
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
