Modifying the air intake...questions
Old Mar 2, 2001 | 02:17 PM
87 Firebird's Avatar
I've been thinking a lot lately about changing a bunch of stuff in the airbox system in my bird. What I plan on doing is removing that secondary air box (the one that attaches to the rad, and does nothing but cut airflow) and redoing the whole intake to consist of: K&N filter, MAF, Throttle body. I'll use some straight plastic pipe stuff to join them. Has anyone done anything like this? If so, have they had any problems? Thanks for any input.
Kevin-87 Firebird 2.8 liter A4
!Cat, !Maf, !Air Intake, K&N, Bosch Platinum +4, Blue Streak Cap & Rotor
Performance Rebuild in the planning stages...
Best 0-60 10.26 seconds...for now
Old Mar 2, 2001 | 10:09 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
I plan on doing something like that sometime. Anyone know what that box between the MAF and throttle body does?
My only mod: Flowmaster 40 series
Old Mar 2, 2001 | 10:33 PM
Yeah, I do. It wastes space, adds weight to your car, costs $$$, and restricts airflow. Seriously, though, I think it's supposed to muffle the noise of the air intake. Screw that, I WANT cool intake noise.
Old Mar 2, 2001 | 10:35 PM
Engine: 2.8, LS1
<font face="Verdana, Arial" size="2">Originally posted by 87 Firebird:
</font>
RIGHT ON!!!!!! Thanks. Now I know i don't need it.
Old Mar 2, 2001 | 10:47 PM
Yeah, I'm quite sure it's useless. I've had it off, opened it up, and seen that it's just a bunch of baffles and ****. Come to think of it, though, it may have something to do with preventing water from getting to your TB, but I'm sure you'll find a way around it...best of luck, and I'll let ya know how my mod goes when I do it. TTYL
Old Mar 3, 2001 | 02:40 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Uhmm.. they wouldn't put a water stopper between your MAF and TB.. that's just silly.. any water blocks are going to be before the filter.. once it makes it to the MAF you're gonna have more problems than a little wet engine (shorts in MAF, MAF fries, ECM might fry, nearby circuits might fry, time to either go replacing a whole buncha schtuff or get a carb) so.. uhmm.. actually I think it's their cheap attempt at getting air to make a decently smooth 90* turn (if this is the piece I'm thinking of).. decent exhaust piping will do the job quite well, and polished will look an awful lot better (personal thought, accuracy not garaunteed).
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
Old Mar 3, 2001 | 10:57 PM
Engine: 2.8, LS1
There might be a little longer delay than expected on making my own intake. I've decided to fix the rust and get a new coat of paint, one WITH a clear coat. I still may do it anyway since it's kinda cheap. But, do keep me posted on any problems that may come up.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
