Timing chain replacement on 3.1 ?
Old Mar 20, 2001 | 11:38 AM
Sincat_23's Avatar
I was reading that you have to take the oil pan off to replace the timming chain because of the cover. That seems to be a very big pain in the A$$! Can anyone give me any specifics? I would really appreciate any help. Is there any thing else I should replace while in there.
92 Camaro 3.1 V6 (Red)
-Hypertech Chip
-Dynomax Exhaust
-Taylor Spiral Spark Plug Wires
-2.5 Harwood Lift-Off Cowl Hood
-B&M Megashifter
-B&M Shift Improver
-15x8 Crager 5-Star Chrome Rims
-JSP Apache Wing
-Yellow Weapons-R Intake Filter
-Custom Cold Air Intake
-KYB Shocks & Struts
-Borla Exhaust Tips
-MSD Coil
-Air Lift 1000 Load Assist Springs
-EnergySuspension Swaybar Bushings and Links
Old Mar 20, 2001 | 03:30 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
no, there is no need to loosen the pan. the timing chain cover consists of like 4 or 6 bolts and it just slides right out. if you choose to do this, take my word: REPLACE THE TENSIONER!!!!!!!!!!!!!
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Mar 20, 2001 | 06:12 PM
KED85's Avatar
Hey, Dan's got it real right!
I swapped the chain.
Take off water pump, take off timing chain cover. Get a timing chain gasket set from Pep Boys, use Fel Pro gasket kit.
OR call these guys, 800-831-0884 Northern Auto Parts. I had everything deliverd to my door for about $50, chain, gaskets, not my labor!!
Balancer, go get/borrow the proper balancer puller from an auto parts store. Be careful pulling balancer, get the engine at #1 Top Dead Center first, then go to work.
BE REAL CAREFUL with the bolts into the timing chain cover. Go slow and make sure they are threaded correctly, don't strip them.
Use plenty of RTV black or Red on all seals!!
Watch out for stuff falling into oil pan, cover that hole!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited March 20, 2001).]
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
