Rear Main Problem?
Old Mar 29, 2001 | 09:49 PM
Vortex_89rs's Avatar
Rear Main Problem?
Does anyone that has a 2.8 have a rear main leak? I have had 2, an 88 and an 89, and they both started leaking at 150k miles. My friend had an 86 that leaked also. Anyone else think this is an inherant problem?
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Mar 29, 2001 | 10:07 PM
Camaro_hunter_d's Avatar
It may not be the mains...it may be the rear cam button seal...
Old Mar 30, 2001 | 09:32 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yep.. I've had that leak since at least 140k miles.. definitly rear main.. front main too.. and a little trans to boot.. Someday I'll have this car happy, I swear.. .. someday..
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
Old Mar 30, 2001 | 05:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It might also be the 1-inch-inside-diameter O-ring seal on the distributor shaft. The rubber o-ring hardens up over time, and loses it's sealing ability. It mimicks a rear-main seal leak, too- the oil runs down the back of the block and around the rear of the crank.
I could've sworn I had a rear main leak; I even pulled the flexplate inspection cover to see oil around the back of the crank. My mechanic told me (after he was trying to diagnose my no-start problem by rebuilding the distributor) that he fixed my oil leak- and he showed me a very-cracked & brittle o-ring. Sure enough, the leak was gone!
You can buy a 5-pack of 1 inch I.D o-rings from Pep Boys or AutoZone or etc... look for where they have their metal drawers in the aisles; usually by the nuts & bolts. Or a "real" parts store will have their own O-ring assortment behind the counter, and can give you an o-ring for $0.50 or so.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
