Ajustable Fuel Pressure Regulator for our 2.8's
Does anyone know if there is such a thing? I've heard that you can use a Holley regulator for the 5.0's but has anyone done it? Us 2.8 guys should look into it because our 2.8's can use all the boost they can get. I know V-8's get a significant increase in HP and tourqe by ajusting their fuel pressure, so why shouldn't we? Hehe! thanks guys.
Car: 1986 Firebird
Engine: 2.8 V6
Well, they don't get significant gains, maybe 5-10 HP. The v8'ers mainly get a gain after doing extensive flow work to the engine (head porting, cam, etc). After that work, the engine flows too much air for the stock regulator's fuel, and the engine runs lean.
I wouldn't say it'd be a good "first" mod, but if you've done a ton of things, look into it. And yep supposedly the v8 TPI fuel regulators are the same for our MPFI ones. I've heard of a few that've done it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
From: First one out of liberty city, burn it to the ground
v8 afpr bolts up...at least one specifically for a 305tpi i believe..thats what my friend with a 3.4 is using..
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
1989 Firebird
I dunno, I figured most of us are suffering from not getting enough air? Seems to be the case with my car, higher revs would run smoother if I had some kind of force flow system... I think...
9192camaro
16
Feb 3, 2019 12:21 AM
