How many V6 owners are there on this board?
Old Jan 29, 2020 | 08:34 AM
  #101
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Re: How many V6 owners are there on this board?
Another one here!
Old Mar 17, 2020 | 07:31 PM
  #102
DIPDAVIS's Avatar
.does this count?
Old Mar 18, 2020 | 04:28 AM
  #103
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Counts in my book. Years ago, I owned an Austin Healey sprite (non bug eyed). I would have loved to have done your swap. By the way, dig your hood prop. Post up some more pics. Nice job.
Old Mar 18, 2020 | 12:36 PM
  #104
DIPDAVIS's Avatar
Fav pic of my favorite kid
Old Mar 18, 2020 | 03:14 PM
  #105
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
Originally Posted by Bob88GTA
Little 3.8 turbo here.
why are you posting the best wallpapers in small format LOL ....I just love this ,it has the car ,the flag ...just too nice.
Old Apr 16, 2020 | 06:08 PM
  #106
88coupedoop's Avatar
New to the forums 1988 v6 2.8 checking in.
Old Apr 23, 2020 | 03:32 PM
  #107
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
1992 3.1L here!
Old Jul 8, 2020 | 09:46 AM
  #108
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
1992 3.1L to 3.4L swap here
Old Jul 11, 2020 | 04:00 PM
  #109
Have been going back and forth about doing an ls swap...$$$$ is what is holding me back. I put nearly 50k miles on this from 1999-2002. Now it's been sitting for 17 years and just got it back a couple of months ago. I've been going through the forums reading and reading. I really want to put a battery in it and see if it even fires.
v6 2.8 5sp 88sc
Old Jul 11, 2020 | 11:23 PM
  #110
StevenJCH's Avatar
Car: 87 Firebird
Engine: 2.8l 60° V6
87 2.8 Mpfi. Here aswell!
Old Sep 7, 2020 | 03:29 PM
  #111
Nova73's Avatar
Car: 1986 Camaro Sport CP V6 MPF
Engine: V6 173cu MPF
Transmission: 700R4 Automatic
86 Camaro V6 2.8L MPF here also
Old Jan 2, 2021 | 08:43 PM
  #112
Torqjunki's Avatar
Car: 1989 Iroc
Engine: Cammed LS3
Transmission: 4l80e
Axle/Gears: 4.10
Found a 1989 bright red V6 Camaro today. Too wet to get to it due to a few days of endless rain. Will pick it up next week. It is auto trans, no t-top car with manual windows. I’m guessing it is a RS and wondering If it is a rare combo. Anyone have this option combo?
Old Jan 3, 2021 | 03:39 AM
  #113
Nova73's Avatar
The VIN should tell you whether it is a RS or not. I have a 86 Sport coupe V6 automatic with wind down windows. Replaced just about everything you can think of body, motor, brakes, ignition, you name it, I most likely had to replace it. Recently the motor was not performing well, so I added a can of Red Line Fuel Injection cleaner and filled the gas tank up with Shell gas. What a difference it made. Would highly recommend doing that to your engine. If you have Chevron gas and chevron tech fuel injector cleaner that will also work as well.
John-Akron,Pa.17501
Old Jan 3, 2021 | 09:29 AM
  #114
Torqjunki's Avatar
Car: 1989 Iroc
Engine: Cammed LS3
Transmission: 4l80e
Axle/Gears: 4.10
Thanks for the info. It appears GM does not break down production numbers for hard tops and t-top cars. My LS swap ‘89 has no t-tops and crank windows also. I’m going to try and get this v6 engine running. It hasn’t run in several years. If it’s toast, I have a late 90’s vortec 305 and third gen serpentine set up I will swap in with carb intake for simplicity.
Old Jan 13, 2021 | 03:52 PM
  #115
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I'm still here with my turbo 3.4 '85 bird. Now rebuilt because i ran it too lean and touched some ring lands. just got her back together and about to install some crane full roller rockers.
Old Jan 19, 2021 | 07:39 PM
  #116
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
I'm here also. I have a 2.8 that is in the middle of a gasket refresh and mild hand porting, or more like removing the factory head defects around the valve guides and bowl blend.
Old Jan 29, 2021 | 04:12 PM
  #117
qmcdugan's Avatar
Car: Camaro Sport Coupe 1984
Engine: Carb 2.8L V6
Trying to get my 2.8 back on the road after two years of sitting. Fuel pump pressure is way low. Hopefully that is all that's needed. I use to get in the low to mid 30s for mpg and 41 on the interstate. Re-freshed the fuel in the tank, but it ran like crap due to the low fuel pressure. So now. Drain the radiator and get that pump replaced. In January on the driveway? What a chore!
Old Mar 1, 2021 | 08:12 PM
  #118
Sstessman's Avatar
Car: 1985 chevy camaro
Engine: 400 sbc
Transmission: th350
85 2.8 mfi here though she won't be for long due to mine sadly giving its last clunk be on the v8 board after that but ill come back when I pick up another v6 3rd gen!
Old Sep 23, 2021 | 09:36 PM
  #119
86_b1Rd's Avatar
Car: 86 Firebird
Engine: 2.8l V6
My 86 Firebird is a 2.8L V6. I've owned it since new. Getting hard to find some parts like an OEM style radiator with the fill neck on the drivers side. Any leads?
Old Sep 24, 2021 | 02:11 PM
  #120
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
have you tried ordering fro ma local parts store like napa / oreilly? they probably don;t stock it but can ship it in perhaps
Old Oct 1, 2021 | 06:18 PM
  #121
Sstessman's Avatar
Engine: 400 sbc
Transmission: th350
[QUOTE=86_b1Rd;6442572]My 86 Firebird is a 2.8L V6. I've owned it since new. Getting hard to find some parts like an OEM style radiator with the fill neck on the drivers side. Any leads?
I got my old one which was brand new but like i said my v6 took its last clunk so i swapped to v8 dm me for photos wouldn't mind getting rid of it since its just taking space in my garage at the moment also this one hasn't had an overheat like the one before it
Old Oct 1, 2021 | 06:22 PM
  #122
Sstessman's Avatar
Engine: 400 sbc
Transmission: th350
i tried that myself for me none of the part stores had one except oriellys but they had to ship it to my location and they lost it so i dont expect much from anyone with our cars lol
Old Sep 9, 2025 | 09:07 AM
  #123
Walker89rs's Avatar
Car: 1989 Camaro RS
Engine: 2.8 v6
Originally Posted by micktroup2
Just wondered how many V6 owners there are on this forum. Don't chime in one at a time for god's sake(!), but if anyone knows a number...
at least one more! ; )
Old Mar 17, 2026 | 01:10 PM
  #124
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
I have 1992 RS V6 with a manual transmission.
Old Mar 23, 2026 | 12:35 PM
  #125
YourRowdy2.8's Avatar
Car: 1986 Camaro Sport coupe
Engine: 2.8L
Axle/Gears: Whatever it came with factory :(
Im a little late to the party but I've got a 86' Sport Coupe with the 2.8 and the 700r4, soon to be a 4.8 ls
Old Mar 23, 2026 | 06:45 PM
  #126
Curvewrecker's Avatar
1989 Firebird 2.8 Automatic checking in.
Old Mar 25, 2026 | 03:05 PM
  #127
codyman125's Avatar
Car: 1989 Firebird
Engine: 2.8 Liter V-6
Don't chime in one at a time for god's sake!
entire forum proceeds to chime in one at a time for the next 15 years
God I love forums.
Old May 30, 2026 | 10:33 AM
  #128
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Resurrected this 1986, V6, MPI, after sitting for 28 years in a garage 4 years ago. So glad we did.
Canucklehead
Convertibles
Feb 22, 2026 08:21 PM
uNkleStv
Oct 24, 2010 08:38 PM
zerogauge
Feb 27, 2001 07:39 PM
