All the sudden she sounds like a truck!
Old May 1, 2011 | 12:56 PM
Inlovewithan83's Avatar
I have a 1983 V6 Camaro. While driving the other night all the sudden I heard a noise of something snapping and my camaro sounded like the loudest lawn mower on earth, the noise appears to either be coming from the engine or just underneath it. The car seems to have lost a little power when accelerating and when I give it gas the sound gets almost ridiculously loud, sitting idle too it eventually stalls out but will start right back up. I should also mention I recently replaced the clutch, but not sure if that would have anything to do with it.
Any suggestions on what I should be looking at first?
Thanks!
Old May 1, 2011 | 01:34 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: All the sudden she sounds like a truck!
most likely the exhaust broke.
Old May 1, 2011 | 01:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
^what he said
the exhaust broke somewhere, look under the car and see where. its probably hanging.
Old May 1, 2011 | 04:34 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Could be the gasket that connects the manifolds to the Y-pipe, but the fact that it stalls out after idling for a while points me at the cat, maybe... if the cat has gone and the guts of it get pushed to the back of the convertor and plug it, it will choke the engine, AND OVERHEAT IT. Mine did that and my EGR valve MELTED to the exhaust!! If it is just a blown gasket or broken pipe, it would just run loud, not stall out...
Old May 1, 2011 | 04:47 PM
Engine: 3.8, 3.4
Not necessarily, a broken exhaust will make the car run shitty because usually half of it hangs in front of the one pipe such that half of it goes through the whole exhaust and half of it exits at the break, screws things up.
Old May 7, 2011 | 09:47 PM
Hey thanks for the two cents guys! This forum is usually VERY helpful.
Turns out that I blew out a spark plug and that's what caused everything. I never even considered that, I figured it was exhaust right off the bat.
Old May 7, 2011 | 10:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how in the hell do you blow out a spark plug?
Old May 8, 2011 | 03:07 AM
Damn good question, I have no idea myself. When I started the car I could hear it pounding and I felt gusts of air coming from the engine, at first I thought I had a cracked engine block, but then I noticed a spark plug hanging down and plugged it back in and BAM, Camaro back to normal. Tomorrow she'll get a full spark plug change and I will loctite them in!
Old May 8, 2011 | 03:34 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hope the threads aren't jacked up.
Old May 8, 2011 | 04:43 AM
Engine: 3.8, 3.4
Don't loctite your plugs....you will have to change them again at some point, I would def check the threads on the plug and head though, I would also check your timing isn't off, I honestly don't know how you could blow a plug on a stock engine other than detonation if even that..
Old May 18, 2011 | 09:58 PM
DrexRS's Avatar
Engine: 305 TBI
Transmission: 5 Speed Manual Transmission
Axle/Gears: Stock
I just had the exact problem. The problem with mine was that the EGR Valve had a exhaust leak. Its an easy fix I went to the junk yard and picked one up for 7 bucks and walaah fixed the problem.
BLK87Z
Sep 18, 2015 11:29 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
david068513
Sep 18, 2015 10:36 AM
Amillionoh7
Sep 11, 2015 11:36 AM
Jlanz55
Sep 9, 2015 09:09 AM
