Rear Wheel Horse Power?
Old Apr 2, 2001 | 09:03 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Okay,
I've been wondering about this for quite some time. Some people say to subtract 15% for drivetrain, and other say 20% for drivetrain.
Which one is more correct, or is it involve an equation?
1987 Firebird
2.8L Auto
T-Tops
New Paint last Fall
No mods yet...
Old Apr 2, 2001 | 10:10 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i say 20% for auto, 15% for manual
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 2, 2001 | 10:24 PM
Ovrclck350's Avatar
I say it would actually also depend on the condition of your transmission.
Old Apr 2, 2001 | 10:30 PM
good point
i think stock trannies with 130,000 take about 25%... so 135 hp - 25%=102...so everything should be in good working order
Old Apr 2, 2001 | 11:34 PM
Camaro_hunter_d's Avatar
After helping build and building several cars there is no way to really generalize the power loss... Though we all cannot go down to the local dyno every time we add something on, a good place to start is like gramesfibird said to look at the condition of the parts being judged...
If they have been beaten up then the loss may not be as bad as you may think. In instances like this it can get the drivetrain "tuned" into a certain positon and help lock it into place. I have seen this happen on cars with as many as 130k miles, the loss was only 12 percent...
While a brand new drivetrain with 7k on it had 32 percent loss... Some thing do get better with age...
Old Apr 3, 2001 | 11:43 AM
Joe_L's Avatar
Car: 1995 Z28
Thanx guys,
well my Trans and engine has 244,000KM (150,000miles) so I guess I just subtract the 25%, and maybe someday when I get it dyno I will be shocked, rather than pissed...
102hp, not the best, but atleast its a # to work with.
[This message has been edited by Joe_L (edited April 03, 2001).]
Old Apr 5, 2001 | 03:21 PM
astro-creep's Avatar
our cars are already rated at the rearwheels!
Old Apr 5, 2001 | 08:15 PM
Joe_L's Avatar
Car: 1995 Z28
<font face="Verdana, Arial" size="2">our cars are already rated at the rearwheels!</font>
Is this true???
Old Apr 5, 2001 | 09:00 PM
3.1 firebird's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Joe_L:
Is this true??? </font>
no its not true, they rate our engines at the crank.
Old Apr 8, 2001 | 03:42 PM
braindamage's Avatar
they quiet rating cars at the crank in the early 70's!!
Old Apr 8, 2001 | 03:48 PM
hate to tell u, but ur wrong.
Gross Horsepower: horses an engine makes at the crank before any accesories
Net Horsepower: horses an engine makes at the crank with all load bearing accesories on (compressor, alt, p/s etc)
1989 Firebird
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
Old Apr 8, 2001 | 06:51 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
yeah, from what i've heard, most cars are rated with Net HP and not Gross. So, we have 135hp with all the added accesories. I've heard that 2.8L's made 200ponies at the once, that might have been Gross HP, not sure. But worth finding out, you could brag the truth, saying my car's got 200 GHP !!!
Old Apr 8, 2001 | 11:29 PM
yeah grames right..back in the 60's the manufacturers were using different rating systems. 1 would rate at the crank with no accesories and others would give the real use horsepower(all accesories on) then they would publish the higher number. The gov said no go and came up with rating at the crank with all accesories on period. The RWHP was never published because the numbers were rediculously low.
Try a 502 aftermaket block rated at 510 HP and 545Pds trq had only 336 hp at the wheels and 450 lbs trq. and this was in a 69 chevelle with a brand new 700R4 and rear end. Do you think that the GM aftermarket parts would advertise this number hell no! but thats what you have to look at.
Old Apr 8, 2001 | 11:46 PM
Ovrclck350's Avatar
Well, they also don't publish RWHP because it depends on EVERYTHING behind the motor, and with as many options you have w/ transmissions and gearing, it differs, so they just report it at the flywheel.
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
