running valves?
Old May 6, 2011 | 04:48 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
running valves?
i need to run my valves since i changed my engine, i also swapped intakes so when i reinstalled new intake gaskets i had to remove the push rods. can anyone tell me how to run the valves? please!!
Old May 6, 2011 | 10:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: running valves?
If you actually mean that you want to know how to set the valve lash, you clean the pushrods until they're not greasy anymore and then set the engine to #1 top center (#1 pushrods fully retracted, valves closed). Any valve that doesn't have the pushrod extended compared to the rest (lifter opening valve) gets tightened until there is no vertical play in the pushrod (you'll feel the difference... Try to avoid using a ratchet on this as it's less accurate) plus 3/4 turn. Turn the crank over 1 full turn to #4 TDC and tighten the rest.
Old May 7, 2011 | 08:21 AM
Engine: L31 350
Re: running valves?
yeah, i made the mistake of tightening them down when i got the valves off because i remembered when i rebuilt my buddys lt1 he tightened his down that way, but since i had to remove the rods anyways to replace the lower intake manifold gaskets i need to run the valves to get them right again. also my step dad said he had to have the car running to be able to do this? correct? or do i get the same effect doing it the way you explained?
Old May 7, 2011 | 12:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: running valves?
Don't run the engine to tighten the valves. You'll be working in an oily cloud because the oil that squirts out of the pushrods WILL end up all over the exhaust manifolds. And besides, you'd have to take the whole top end apart to put the valve covers back on anyways.
gta90
Sep 15, 2015 04:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
jackhammer
Aug 15, 2015 10:04 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
